Did the problem start after the axel was replaced? If so, I have the exact same problems (I've posted about them before). My car was making a poping noise, brought it in for a new drivers side axel, picked it up and noticed a vibration when I accelerated (all gears, all angles of steering wheel)! I had that axel replaced again (under warranty) and even replaced the pass. side in order to try to fix the problem. Every place I take it to says (CV joint/axel). My next move will hopefully be to get my hands on some OEM (read new) axels and replace both remanufactured ones. If that doesn't work, I'll look into replacing all of the motor/transmission mounts. (I know, do the cheap stuff first, but I have an extended warranty so both will cost about the same to me in the end).
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
