#1401347 10/03/05 03:57 PM
SCSVT Offline OP
I recently changed my trans fluid on my 2000 SVT( I think).
I am concerned I may not have put in the right fluid.
I got a little confused with the how-to and am still unsure if I changed the right thing and if I even put the right fluid in. Sorry I'm new to this!
I drained the fluid out of what I believe is the tranny and it was reddish in color. I then replaced the fluid with Mobil 1 fully synthetic gear lubricant(This is what the How-To stated). The Mobil 1 is honey colored and it required me to use a pump to get it in there(I used about three bottles). While at the auto parts store the parts guy said I should be using the MTX fluid to replace this(this would make sense in that this is what I drained). I went ahead and changed the fluid with the Mobil 1 dispite his input.
The How-To stated I would notice a difference in shifting feel after replacement but I haven't experienced this.
Did I replace this correctly? If not, what should I use to get this gear oil out and replaced?
#1401348 10/03/05 03:58 PM
H
H
This forum should help
'98 SVT Red/midnight blue - a few mods E0 wheels for sale - PM me
#1401349 10/03/05 04:57 PM
Current ford spec calls for a special formula called "Ford Honey". Do a search for the correct part number. No FM additive should be used.
If you want aftermarket fluid, the Royal Purple Synchromax is probalby the only product that adheres to the Ford Honey specification.
#1401350 10/03/05 05:17 PM
I replaced mine with the Ford "honey" fluid last Thursday. You can get it at a dealership, ask for part number XT-M5-QS. Be prepared to pay $20 per quart, unless you know someone there who can get it for $15. You'll need 3 quarts, though it may only hold a little more than 2.5 quarts.
I did notice smoother shifting immediately following the change, however, it has stiffened up a bit since then.
If you aren't a real aggressive driver then I wouldn't worry about about using the Mobile 1 synthetic.
Black 2000 SVT Contour w/ Prairie Tan MSDS Headers | Magnaflow | Mirko Splitter | Fidanza Short Throw Shifter | Kenwood KVT-815 LCD/DVD
#1401351 10/03/05 05:58 PM
SCSVT Offline OP
That forum just made me more confused!
Anyways, thanks for the responses. I'm not exactly the Sunday driver so I just might go ahead and replace the fluid with the Ford "honey".
This kind of goes with this thread. Is it a complete pain in the a$$ for someone without a lift to get in there and disassemble the differential?
Can an average do it yourselfer tackle this?
#1401352 10/03/05 06:00 PM
a tranny drain-fill??
#1401353 10/03/05 06:12 PM
SCSVT Offline OP
Sorry- I'm not sure where that came from.
I was just wanting to know how difficult it would be to get the tranny open in case I ever needed to.
#1401354 10/03/05 06:27 PM
Ahh.
Engine/Tranny out through the top in one piece... (FAR SIMPLER!!!)
Tranny out the bottom by itself... (remove subframe, etc, etc) (harder, but DOABLE IF you have experience)
Ray
#1401355 10/03/05 06:45 PM
Mobil 1, or ANY GL-5 gear oil is not safe for the syncros or brass bits. Drain it immediately.
#1401356 10/03/05 07:05 PM
To get to anything inside the tranny (differential, synchros, etc) requires removal of the trans from the vehicle. Which means either pulling the engine, or dropping the subframe and pulling it out the side. Either way, its LOTS of work and expensive if you have to pay a shop to do it (~8hrs labor at some places)
