Posts: 343 |
I just had my rear subframe worked on and found out that the mechanic didn't "preload" the bushings. This procedure is described in the "rear suspension clunk" thread, but my mechanic wants the Ford write up or whatever on how to do it. Does anybody know where I can find this, or how to get it from the Ford service manual or anything?
TIA
99 T-green svt
K&N & heatshield
Opt. y-pipe
Borla
Superchip
DMD
Magnecore wires
Metal impeller water pump
BAT / Bilstein kit
21mm BAT bar w/ boxed subframe
215/45/ZR17 Toyo Proxes FZ on Rage 5.0's
jimmkreider@yahoo.com
Posts: 2,007 |
From what i understand all it means is that before tightening all the rubber bushings, you let the car down so that it's at the equilibrium position (at the ride height that it will be at when parked on all 4 tires)...then tighten the bushings so that they are not loaded at this position. I did it when i installed the BAT kit, but it was tough to fit my big arse under the car...ramps might help out. ...At least i think that's what you're talking about???
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 6,910 |
yes, when ever you replace bushing you need to have the car at ride height, ie on the ground before tightening all the bolts up. this does not induce a stress in the bushing from the weight of the vehicle
- 95 Mystique LS - Zetec/5spd
Posts: 343 |
1) I will have about 600-1000 miles on the car since the subframe has been redone and put back on without preloading the bushings. Has the damage already been done or is it alright to loosen it up a little and do it properly?
2)Would it be ok to put it on the lift and only raise it up an inch to do it, or does it definately need to be at normal ride height?
3)Also, I just had the car aligned, will i need to get it re-aligned after preloading the bushings?
99 T-green svt
K&N & heatshield
Opt. y-pipe
Borla
Superchip
DMD
Magnecore wires
BAT / Bilstein kit
Posts: 5,810 |
Originally posted by csvt99: I just had my rear subframe worked on and found out that the mechanic didn't "preload" the bushings. This procedure is described in the "rear suspension clunk" thread, but my mechanic wants the Ford write up or whatever on how to do it. Does anybody know where I can find this, or how to get it from the Ford service manual or anything?
TIA
Damn, it isn't hard. Just put a jack under the lowest point of the hub where the trailing arm bolts to it and jack it up until the wheel is at stock ride height.(this assumes you have the car up on jack stands already) Loosen all the bolts on the control arms and trailing arms a little so that the bushings relax, then retighten. Then remove the jack....then peace of mind.
I will tell you that several years ago when I did my rear springs I never preloaded the bushings. They are still good and not worn out. However, I did preload them this time just for good measure since I know now.
See My Mods
Posts: 343 |
Thanks for the "how-to". Heck I just think I'll do it myself when I go home this weekend and change the sway bar bushings.
99 T-green svt
K&N & heatshield
Opt. y-pipe
Borla
Superchip
DMD
Magnecore wires
BAT / Bilstein kit
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
I beleive Todd's Hot Garage CD, has details on it.
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 21,197 |
Most likely.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 343 |
I think I'm just going to do it myself...which bolts do I need to do? I'm assuming is the 4 on the rear subframe and and the bolts on the rear control arms (to the subframe). Anything on the front?
99 T-green svt
K&N & heatshield
Opt. y-pipe
Borla
Superchip
DMD
Magnecore wires
BAT / Bilstein kit
Posts: 5,810 |
No, do not loosen the ones on the subframe. Only those bolts where the control arms connect to the wheel hub assembly. There should be 3 total per side.
Assuming the back of the car is up on jackstands with the wheels about one inch off the ground (front not necessary to be off the ground): Put a small floorjack under the lowest point of the control arm and jack up the wheel/hub until it is sitting about the right height in the wheel well. Wheels can be off for this and you can get to the bolts easier.
There is one bolt and a big washer on the rear control arm. Loosen this one, let the bushing relax (happens as soon as the bolt loosens) then retighten it. The trailing arm (I think its called that) has the bolt that goes through a u-bracket. It is also the lowest part of the hub assembly. Loosen this then retighten. The front control arm (the one with the rubber pieces in it) is bolted through the control arm with a bolt and a nut. Loosen these, retighten.
Thats it. If there was tension in the bushing you can see it turn when the torque is released.
See My Mods
