Page 3 of 3 1 2 3
Originally posted by mystiquevltwin:
oh yeah i know all of that...i did shave the little tabs inside the light socked...but the problem i am having is that the diameter of the low beam does not fit in the high beam socket....im talking about the circular part on the headlight itself...what gives?!
are silverstars a smaller diameter than stock headlights?...they shouldnt be?! or am i doing something wrong
I know this is old and you probably figured it out by now, but this mod is to put the High beam bulbs in the low beam socket. Sounds like you were going in reverse
www.ChicagoCEG.com 2006 White Grand Prix
I actually just did this mod and I'm going to stick with the low beams in the low beam socket. Shaving off the tab is no issue, but the circumference of the gasket part of the high beam bulb is smaller than the low beam bulb. It will work but the fit is not very good, the bulb has a tendency to go in crooked and screw up the direction of the beam of light coming out of the headlight. I don't know if I just didn't give it enough time but it just doesn't seem like the fit would be reliable for keeping out moisture, or for keeping the bulb perfectly straight in the socket.
6450 of 6535 6-16-98
Page 3 of 3 1 2 3
