So I took�er out last night.
Initially, I wasnââ?¬â?¢t impressed. Not as much as Iââ?¬â?¢d anticipated, but I think Iââ?¬â?¢ve got a lot of simple improvements thatââ?¬â?¢ll make for the gains Iââ?¬â?¢d hoped for. After about an hour, I started to realize that what gains there were, were not in the top end, but all in the torque curve. Anything over Ã?½ throttle seems to be a waste. And the throttle ââ?¬Ë?tip inââ?¬â?¢ is very sensitive. Like its dead right off idle then boomââ?¬Â¦ gobs of torque, but there isnââ?¬â?¢t much if any of that ââ?¬Ë?rush to redlineââ?¬â?¢ the ole 2.5 had.
Without doubt, it�s faster. My ADC chip is in the mail, so I�m anxious to see what that�ll provide. Next Saturday I�ll be having the y-pipe modified. I�ve still got stock 96 exhaust, and I feel that could be robbing me of the volume of air the 3L needs to move in order to let it breathe in the upper rpm band.
So once the engine is tuned, and I get an exhaust on it, I hope itââ?¬â?¢ll be everything I expected. Iââ?¬â?¢ll be ââ?¬Ë?testingââ?¬â?¢ it more today and let ya know more. Iââ?¬â?¢ve only got about 45min on it so far.
Cheers,
John
PS: BTW�. My new SVT suspension really gives it that Audi All Road kinda look.
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
9
John,
Check dyno and drag section... I took it to the track last night...
You should get headers and true duals...
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
Congrats on finally getting it going! Exhaust for sure will open it up. obviously you're running 3L heads if you're not already using a chip?
If you don't mind me asking,approximately how much was the install,because I am very seriously considering a 3L swap next winter. You can PM me about that if you want.
Anywhoo,have fun with it,for what's left of the season anyways!
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
Moderated by  Gerald_dup1, mbb41_dup1
