Page 2 of 3 1 2 3
#1397818 10/01/05 01:43 AM
W
W
Man, inspection in Texas is pretty easy...
HOok to computer, everything good, okay...
Brakes work? Lights work? Good...
Inspection DONE!
#1397819 10/01/05 01:51 AM
YOUR part.. maybe.. mine is easier.
no computer.
brakes? lights? horn? k.. you're outta here
Ray
#1397820 10/01/05 03:18 AM
Time to call Stazi
#1397821 10/01/05 04:06 AM
W
W
no computer.
Ray
OH yeah, I forgot the horn...
Older than 1996 or whenever OBII came out, gets the drive for 90 seconds with a sniffer...
#1397822 10/01/05 12:50 PM
jlyon Offline OP
were i live, we don't have emmision tests. that is why i don't understand. oh well, it is inspected now, so i am happy. just won't be going to that place for anything now.
lets try this again. this time, lets try not to get bent outta shape:D
#1397823 10/01/05 01:30 PM
Tony
Tell me it is simple to change belt!
I hope I do not have to un-bolt engine mounting brackets!
I once had to change the serpentine belt
#1397824 10/01/05 01:31 PM
Maryland is the worst for inspections, in two ways.
First, it's the most ridiculously strict inspection I've ever seen. I personally had a car flunk for: a few drops of condensation in the headlight lens, a burned-out foglight (it's perfectly fine to not have foglights at all, but if you do and one's burnt out, that's unsafe! ), a few hairline cracks in the serpentine belt, and a loose headlight switch knob. It wasn't broken, it wasn't falling off, it was *loose*. And I took it to a place that had a reputation for being lenient! My dad had a car flunk because the seatback had about 1/4" of free play.
Now what makes this even more ridiculous is that inspections are only done when the car changes hands. Once it passes that initial inspection, you're free and clear to run your tires down to the cords, wear the brake pads down to the backing plates, and drive around with burned out brake lights. It's basically a scheme to make mechanics a bunch of money, while doing essentially nothing in the way of keeping cars in safe condition.
'99 Contour Sport V6 MTX
#1397825 10/01/05 10:01 PM
Originally posted by rearden:
I personally had a car flunk for: a burned-out foglight (it's perfectly fine to not have foglights at all, but if you do and one's burnt out, that's unsafe! )
I had a gate guard get on me for having one burned out. I was like "uhh.. ok."
I haven't yet had to get a car inspected... maybe that'll change in Germany, but I dunno. When I get back to the states from there, I'll just register it in Iowa (no inspection).
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1397826 10/01/05 10:16 PM
Originally posted by dharnie:
Tony
You decide. Read this thread. No, you do not have to un-bolt engine mounting brackets.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1031104&page=&view=&sb=5&o=&fpart=1&vc=1
#1397827 10/02/05 02:00 AM
no inspection here unless if you remove the licence plate on the car for more than 1 year or if you by it from a different province or from US
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
Page 2 of 3 1 2 3
