Page 3 of 4 1 2 3 4
That weber-alpha design would be fine in a kit car but did anyone notice that the stacs on the carbs would be facing the firewall if you put them in a Contour?
E
E
First, there is a COMPLETE difference between a CARB' and a THROTTLE BODY or THROTTLE BODY INJECTION or MULTIPORT INJECTION. DO NOT CONFUSE THEM. A carb operates independantly from any sort of injection device(I know there were some quasi-computer controlled piles of carb's but they still did not use an injector ). A throttle body is basically a air control device that restricts air from entering the intake manifold. There are throttle body injection setups that have a pair of injectors that spray into the throttle plate of the throttle body. Basically a single point fuel injection setup that was an interesting twist on a carb in an effort for manufacturers to save money. Not as efficent as a multiport setup though. Now the setup that was pictured in your link (the red zetec engine)was a multi throttle body, MULTI PORT FUEL INJECTED SETUP not a CARBURATED setup. What we are talking about here is a complete REMOVAL of the FUEL INJECTION SETUP of the car. We would install a pair of Weber carburaters that DO NOT USE ANY SORT OF FUEL INJECTORS OR A COMPUTER TO CONTROL THEM. Yes, you will have to install a computer that has the ability to read off of a magnetic crankshaft sensor/pickup assembly to control the ignition. (since the Zetec and the Duratec doesn't have any sort of a distributer) But the computer would control ONLY the ignition chores.
Obviously you have never owned or worked on a vehicle that didn't have fuel injection on it. If you did, you would understand that back in the day you only needed about 3 wires under the hood(except for spark plug wires) to make an engine run. Carburation works completely null of any sort of electronic help.
Basically throw the computer in the trash. Install a pair of carbs for the fuel. Install a stand alone ignition control. Enjoy SIMPLE, EASY TO MODIFY and CONTROL POWER. Install whatever you would like, there isn't a EMS in the car that says 'I DON'T LIKE IT'. I keep my 10 second carburated 5.0 around just so I can remind myself of how simple things used to be .
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
H
H
Heck Yeah. That's what I want, a Contour that, when the gangs take over the highway, will continue to run. Seriously though, an engine you could tune with a timing light and a screwdriver? That sounds like heaven to me. Screw all these computers and $#1t. Oh, I am sure there is a way to make those carbs fit too. I mean, just cut into the firewall.
Actually I have worked on cars with carburetors.
An old style carburetor uses vacuum to inject fuel via a jet (kind of like nitrous) versus an electronic controlled injector.
I am not arguing how a carb works (if it came across like that, then I did not word my statements correctly).
The point I am making is solely about the kit available for our engine.
Here you can see a small carb (very similiar to the weber-alpha ones for the zetec).
Amazing how much it looks like a throttle body.
Now instead of a jet the weber-alpha kit uses fuel injectors at the carb/throttle body.
Very similiar to throttle body injection.
The kit uses a FPR (vacuum) to control fuel delivery (like adjusting the screws on a carb).
The ECU does not controll A/F ratio, simply fuel injector pulse.
The design has many of the positives of both carb & fuel injection and fewer of the drawbacks than each.
The kit brings the zetec to about 180BHP.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
E
E
Look Sleeper, I appreciate you trying to help us with one of your QUASI-FUEL INJECTED offerings. But what we are essentially trying to do here is to install a pair of carb's onto the zetec with somthing to make the ignition work in an attempt to have a running engine WITHOUT a COMPUTER OF ANY SORT FOR FUEL CONTROL. Try to invision a Holley 4 BBL 600 CFM on the Zetec. Now if we could manipulate the factory ECU into controlling the ignition system without having control of the fuel injection we would keep it. But since we can't, it must go. Throw out the factory ecu, wiring etc. etc. In it's place drop a stand alone ignition computer that can operate the ignition without ANY OTHER computer in the car. Couple that with the Holley and I think you might understand a bit more. (Of course we are looking to use a pair of weber's instead of a 4 bbl!!) Simplicity. If it had a distributor, I would suggest a retro to a points style ignition with a single ignition coil.
There are those out there that would find a fall back to a mechanical everything under the hood appealing . Fuel injection has brought a great number of successes along with it, but it has essentially locked you and I out of the mix unless we invest some large sum of money into purchasing electronic devices to allow us to monitor and modify what goes on under the hood. Now wouldn't you just rather save the $1000 you just spent for the laptop and the datalogging software and wideband O2 and just trade it in for a trusty 99 cent screw driver that allows you to essentially do the same thing?
H
H
Originally posted by ButtonPuncher:
Yours for only $1200...
http://cgi.ebay.com/Twin-Pair-Dellorto-DHLA-48-C-As-New-Weber-DCOE-SP_W0QQitemZ8004288430QQcategoryZ43120QQrdZ1QQcmdZViewItem
BP
Those Carbs look sooooo cool. I can just see those buggers in my engine bay now.
There is more control and better power from the Weber-Alpha hybrid design.
(There is a reason converting to fuel injection on hot rods is so populaur.)
I do agree that the novelty factor of going straight carb is cool, and can even offer more power than our current fuel injection setup.
As far as where to put the filters for a carb setup;
Simply cut into the firewall and use the area under the windshield cowl as a large intake plenum.
Half the cowl grill (big plastic piece that has the wiper arms sticking through) is a solid piece (and it just so happens its the side where the carbs would come through the firewall) and the other half of the cowl grille has air solts in it, so all you would need to do is add a filter to the underside. Talk about a cold air intake.
F
F
there's company in england (i know bit far 2 go 4 a carb conversion) who can make a custom inlet manifold 2 make the zetec run on bike carbs apparently this conversion is the nuts
cos the bike r designed to run over a much larger rev range it makes the engine very torqi low down & pulls all the way through the rev range but keeps the engine nice and drivable apparently the conversion is quite easy but setting it up 2 run correctly is mustard (sorry very hard) but it works out a dam sight cheaper than turbo or supercharging (although i do believe its a lot cheaper in yr country)
anyway with the conversion alone with no other engine mods (except filter & zorst) b looking at 170/180 bhp on a 2.0
inlet manifold retails at �£176 and the bike carbs can b picked up in scrapyards over here 4 about �£30 i'll give u there phone no. BOGG BROTHERS 01944 738234 im sure there b happy 2 answer any questions
the conversion is also compatible with the 4 cylinder duratech
1995 MK1 MONDEO GHIA X sweet as they come 4 pics and full spec click http://photobucket.com/albums/a92/funkydes/project%20mondy/ best of british mondeo enthusiast group http://www.fordmondeo.org/forum/index.php?referral/19055/
H
H
SWEET. If I ever get enough money or time. Right now I'm working on my friends '88 Firebird. cramming a Vortech 350 in that nizzle. I should get a pretty good overview of how to set up carbs right on that project. That would be such a cool mod though, the only problem with carbureting a Contour/Mystique is the emissions. But then again as my friend says, "$50 to the tech will pass ANY car"
Page 3 of 4 1 2 3 4
Moderated by  Loco4G63
