Page 3 of 4 1 2 3 4
#1396280 10/06/05 08:07 PM
I'm attempting to design and mill a one off Mass air flow adapter. We have a mill at my school and all the proper software. wish me luck. I'll be sure to post pics when I'm done.
1999 Black Contour V6 5 speed. http://www.cardomain.com/ride/2072975/
#1396281 10/06/05 08:12 PM
good luck! i used to work for a machining factory. i hated it. wish i woulda made one b4 i left though.
98' Black SVT Build #1915 of 6535
#1396282 10/07/05 02:34 AM
I got mine from some lame-o ricer store. Don't ask me how they knew where to locate it.
*Formerly Shifty... love my Jetta, miss my 'Tour
#1396283 10/08/05 08:05 PM
where can i get nuts and bolts for the maf adapter and sensor? i bought the adapter from ssd4u.com and the adapter is probably about an inch thick.
#1396284 10/08/05 08:35 PM
I just found some the right length at the hardware store.
98 E0 SVT with some stuff
#1396285 10/09/05 05:11 AM
sounds good to me. i'll try another hardware. i asked b/c the local one didn't have any that would fit. well, at least any that would fit the nut, they didn't have fine thread screws.
#1396286 10/09/05 03:44 PM
I used some lock washers on there too just to be safe.
#1396287 10/09/05 04:25 PM
here's the reply i got from ssd4u.com tech staff
The contour kit uses 4 bolts to fasten the adapter to
the mass airflow sensor housing.
Size: 1/4" x 20 x 1 1/2" with a nylon insert nut
Type: Grade 5 Plated
Use two washers with each bolt so that a washer is on
the MAS housing and the adapter housing.
Sincrely,
Bill
SSD-Tech
#1396288 10/09/05 05:51 PM
you should be able to find those at a hardware store
#1396289 10/09/05 10:31 PM
i did, found them at lowe's.
Page 3 of 4 1 2 3 4
