Posts: 9,872 |
Originally posted by TravisN1: Originally posted by Goonz SVT: Originally posted by Airforce: how much u want for it?
$5500
you can buy a nice SVT with no leaks for less then 5500
oh snap
Posts: 9,872 |
it appears that the leak only occurs during cold temperatures at night, like last night it leaked again and pretty much all my coolant is gone..
Posts: 5,345 |
Originally posted by Goonz SVT: it appears that the leak only occurs during cold temperatures at night, like last night it leaked again and pretty much all my coolant is gone..
Then it should be easy to determine the location. Tonight, wash the underbody where there is coolant, then dry it (with a cloth). Then tomorrow morning, get a flashlight and see where it is dry and where it has coolant. That should help you determine where it is leaking. As posted previously, it is probably a loose hose clamp, loose gasket at the WP (maybe need new screws and gasket) or a tiny hole on a hose. Good luck.
1996 V6 ATX 96K miles
Posts: 6,910 |
Originally posted by Tony2005: Originally posted by Goonz SVT: it appears that the leak only occurs during cold temperatures at night, like last night it leaked again and pretty much all my coolant is gone..
it might be a hit or miss type of thing. the mystique leaked the other winter, I believe two winters ago from around the thermostat housing to the block, didn't do it last year and haven't seen anything resently, but it was cold dependant
- 95 Mystique LS - Zetec/5spd
