Posts: 736 |
First, I tried to e-mail terry and his e-mail addy no longer works. Then, after looking on here for a bit a searching for an answer I would like to pose a question about a tranny swap, so, here it goes.
I have a 99 ATX Contour Zetec and my tranny recently messed up, I am wondering what it wou'd entail, or even if it's possible to swap out an ATX and put in the MTX-75 I know that if it's possible I would need:
1. MTX-75 tranny 2. pedal assembly 3. mtx flywheel 4. clutch 5. probably a new cv at least on the left side 6. all cables and linkages 7. shifter
I'm not sure if there are any electronics in a manual tranny or not so i'm not sure if i'd need the ecu from the other car or even if i would have to change over the entire wiring harness or just part of it.
I am looking at 1500 for a rebuilt tranny and am trying to find a different way around this and happened to think about a manual instead. If it's possible then I have another option but if not could it be explained why.
If you could help or at least shed light on this then it would be greatly appreciated.
Thanks, william
99 ATX Contour 130k w/ a 21k tranny freshly installed
Secret Project in the works
Originally posted by unknown: Never argue with an idiot, ppl may not be able to tell the difference between you.
Posts: 21,197 |
It will cost you that much to convert as well. Most likely will need a PCM as well.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 3,944 |
Here is a decent thread. I found this by doing a search, using "ATX to MTX". There's actually alot of threads, but you will have to do some wadding. Alot of the threads turn into bashing matches, so... but you can tell pretty quick which ones to ignore and which ones are on topic. I also e-mailed you that how-to that I mentioned as well.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 736 |
ok another question, I found a tranny from a 98 that had a v-6, will it fit? I believe I read on here that the tranny's are Identical but I wanna make sure. Will a Duratec 2.5 tranny fit the Zetec or will i need to switch out the bell housing, or what, it's a known good tranny, the engine cratered but the tranny was fine when this happened. and it's only 300.
Posts: 9,065 |
Originally posted by UncommonTour: ok another question, I found a tranny from a 98 that had a v-6, will it fit? I believe I read on here that the tranny's are Identical but I wanna make sure. Will a Duratec 2.5 tranny fit the Zetec or will i need to switch out the bell housing, or what, it's a known good tranny, the engine cratered but the tranny was fine when this happened. and it's only 300.
No it won't fit. Bellhousing is diff.
I suppose you could swap the bellhousing tho!
Posts: 736 |
so, other than the bell housing, it's the same trans? Is there any code numbers or any other difference between the two?
Posts: 9,065 |
The final drive would be diff from duratec to zetec.
Posts: 736 |
so would it be possible to swap out the final drive?
Posts: 9,065 |
I'd say leave it. The duratec final drive would be nice on a zetec...and visa versa
Posts: 736 |
yeah but what's that gonna do to the speedo's accuracy?
