This should put a end to the same questions asked over, and over again.
HID F.A.Q
1. What are they?
HID stands for High Intensity Discharge. HID lamps do not use a filament, instead the light is generated by an electrical arc inside of the capsule. In order to generate the arc, a high energy pulse is produced from the electronic ballast, this high energy pulse produces an electrical arc across the electrodes in the capsule and generates light.
2.Why do HID headlights look blue when they are turned on?
The color of a light is determined by its color temperature. The interaction of the electrical arc and the gasses inside of the capsule give off a higher color temperature (4,100 K) that is closer to true white. So when you compare the color of a halogen headlights (3,200 K) against the color of HID headlights, the HID lamps look blue/white and the halogen lamps appear more yellow.
3.How long will my new HID headlights last?
The HID system is designed to last an astonishingly long time -- up to 10 times longer than a conventional halogen capsule.
4.Is such a bright light legal?
Yes. All XeSighting Systems Headlamps are engineered using the same stringent requirements that Original Equipment Manufacturers demand.
Info taken from www.xesighting.com ******NOTE************
This is true, but any HID kit found in a non-factory equipped HID car is illegal.
YOU WILL BE TICKETED!!! Trust me.
5. What does that kit include?
The kit includes:
2 Ballast
2 D2R BULBS( When ordering make sure you specify D2R,9006!!!)
All the wiring included.
6. How much does it cost?
They retail from $300-$1000. You can easily find them on
www.ebay.com for around $500.
7. How long do the bulbs last?
I am told they should last longer then your car... One more thing. They do blow out. So be prepared to pay $150-$200
EACH for new bulbs.
8.Are they easy to install??
A. Disconnect battery.
B. Unplug lights.
C. Plug wiring harness into ballast.
D Plug wiring harness from ballast to D2R bulb.
E. Upgrade driverside, and passengerside headlight fuses to at least 30AMP.
NOTE: When you turn them on make sure the car is running, they use alot of power.
F. Get a headlight alignment. You don't want to run into the boys in blue with high headlights do you..
9.Why can't I just get the blubs from walmart, pepboys, PIAA etc's??
Well to put it bluntly if you buy any of those blue bulbs. Your better of taping flashlights your hood. Trust me there is a big difference, and remember you get what you pay for.
Well that is it. If you have any questions please contact me at: wright_antonio@hotmail.com
