Hi, I recently had a fog light plug on my car crap out on me, it got all corroded and now it is to the point that the prong of the old light bulb is stuck inside there. I've looked around and can't find anyone that sells the plug itself are they the same on the SVT foglights vs the SE's?? I'm assuming they are and that i can just swipe one from the junkyard cuz they all use the same light bulbs correct? Thanks Tony
CSVT#1321/2150 Born 1/6/2000 It's just a Contour.. Before Dyno: 178.9whp w/2.5L 94 Probe 4cyl/150k KYB struts, Magnaflow Polished SS muffler (Daily Driver)
So, you are talking about the plug that goes in the back of the fog light for the bulb correct? And it has weathered/corroded to the point where it is damaged? Yes, they are the same, just find a junkyard tour' with fogs (pretty sure ANY year will actually work), cut the connector off with some additional wire and splice it on. on the 95-98 tour's, the wire colors will more than likly be diffrent, though. Jst keep that in mind when splicing it.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
I have a set of aftermarket plugs that i plug right into your bulbs PM me...
www.ChicagoCEG.com 2006 White Grand Prix
