Posts: 28 |
Hello,
I'm planning to remove my v6 engine to replace the headgaskets. Can I remove the engine (without gearbox!) from above? Is there enough space when I remove damper, steeringpump etc.?
Thanks,
Mat
Posts: 1,580 |
You can remove the engine and tranny together from above after everything else is diconnected. The radiator, condensor, AC compressor can all stay in the car. The only thing you have to really remove is the intake.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 1,859 |
If you have a manual trany, it all comes out. If auto than just the motor can comes out.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 1,580 |
I apologize. I assumed you had a manual.
** Mike **
Posts: 28 |
O.K. thanks for the info so far. It's a manual transmission. I was hoping I could leave the trans in place! I don't understand why the engine only can be removed with a automatic?
Posts: 4,693 |
Not enough room.
An automatic comes apart from an engine with very little movement of the trans away from the engine (probably less than an inch).
A manual trans must have the input shaft pulled out of the clutch. That could easily take about a foot.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 285 |
Originally posted by dolderman: O.K. thanks for the info so far. It's a manual transmission. I was hoping I could leave the trans in place! I don't understand why the engine only can be removed with a automatic?
It's easier in the end to pull it all out together regargdless of what tranny you have. This way you can have more space to pull the tranny apart from the engine. I pull them out together, set the assembly on a dolly and work on it while sitting comfortably on my rolling garage stool.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
Posts: 21,197 |
Undo the 3 bolts that hold the a/c pump to the block and zip tie to the front of the subframe out of the way, seperate ball joints, remove batt. and batt. tray, remove axle nut and pull axles after draining trans. fluid, disconnect coolant hoses after draining coolant, remove y-pipe and associated 02 plugs, VSS to wiring harness connection, plug wires and coil pack, upper and lower intake manifolds, main wiring harnesses, grounds, PS lines, clutch hydraulic line and vac. hoses. I've only done this 4 times now.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 28 |
Ok guys! Thanks for your info! It helped me very much.
Posts: 1,859 |
Driver side axle can stay in . Its a muther to get out of the trany.
'99 Silver svt
For sale
19" Axis Neo wheels
Check classifieds
