#1394235 09/25/05 09:59 AM
rjclark Offline OP
97 V6,
When I squeeze the upper radiator hose with the engine running I do not feel much resistence. The res. tank is full and theres plenty of heat from the heater, the car is not overheating. Does the top hose take water to or from the engine?
Any thoughts.
Thanks
#1394236 09/25/05 03:27 PM
I am not possitive, but the top hose should be the return hose. That is how it is on most vehilces to keep the water pump from sucking air if the water level gets low. The only time there might be pressure is when the termostat opens and exchanges water, other wise the water mainly circulates in the engine block.
1998 Contour SVT Black w/ Blue interior Torsen LSD updated shiftforks Lightened Flywheel, HD Drivelines Optimized Thottle Body 2003 3.0L engine upgrade (Soon to be)
#1394237 09/25/05 04:46 PM
rjclark Offline OP
Thanks that's good info.
