Y
Y
Ok, With the death of the almighty temp. gauge in my 95' contour I went to the junk yard...ooo the choices with over 6 contours/mystics to choose from I was over whelmed...but I tried to stay within my model year for parts. Anyway, I pulled a gauge cluster from a 95' V6 mystic <-(I think the spelling may be off but the mercury version of the contour), now I would like to put it in my 95' contour...but after doing some searching on your forums I hear there is a resistor I need to solder in somewhere, where would that be and what size? pics would be helpful.
I don't know about the resister, but I do know that in 95 there was a speedometer that used a speedo cable and one that used the signal from the VSS (vehicle speed sensor). You need to make sure that they match. If you have a speedo cable attached to the speedometer on your car, the new cluster will need to have it too, and vica versa.
Y
Y
I belive it uses a signal, well let me put it this way if it does not I'm SOL.
Y
Y
Well, I'll just plug it in and see if it works...
Y
Y
Eh, well I plug the new tach in and it was a no go..nada, no reading zip...but all the other gauges worked well...so uh how do I get the tach working?
Y
Y
ok well I got it worked out, the junktard guys let me extange the v6 tach, I pluge it in and still not worky...*sigh* ford cheaped out and did'nt run a tach wire...so I tied into one of the wires running to the PCM and it works good now...
E
E
I have a 95' zetec without a tach. I installed a aftermarket 5" tach and found a tach reference wire right off of the wiring connectors that go into the back of the cluster. I had also looked for a 4 cyl with tach cluster and didn't find one until I had already installed the aftermarket tach. In my findings I had found that the wiring going to the cluster was different year to year and between engine models. If you are still trying to use the V-6 cluster and have just swapped the 4 cyl tach into it, this may be your problem. You may want to check your pinout and make sure it is the same for the other circuts on the cluster. I have helped a few others with contours and a mystique install tachs into thier cars that were not equipped with them. However your trying to stay with stock.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
Y
Y
nononono...it works now...I'm good
