Posts: 869 |
Originally posted by Dj Perico: I was think the kit will work because I'm thinking of getting me a zetec Contour soon. Is there and way a shop can fabricate the intercooler, intercooler plumbing, and tuning to make it work?. Logan B are you getting if so. Where are you getting it done at?
I am doing the fab work myself because I am crazy like that but a great shop in NC that would do it is. True Blue Performance.
http://www.trueblueperformance.com/
Give them a call they are great people.
Posts: 228 |
Thanks Logan I just go there when I go to Va Beach. Millennium Autosports This place right here do good work they did a couple of my friends rides. So I might check them out also.
1999 Ford Contour 2.5V6 5peed Se Sport.
Aim djperico
Looking for svt front and rear bumpers.
Posts: 5,143 |
Originally posted by LocoSCZ: Originally posted by Wulfen: A supercharger will take you about 40hp just to make it run with an I4. The turbocharger will use lost power from the exhaust, more efficient that way.
Boost is boost.
And a supercharger is way better on the engine.. had hector put a turbo in his Zetec ATX Tour.. yes, he would have had more power, but probably desroyed his engine well before the miles it actually has on it... What is your Zetec at now hector? 145K?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 869 |
Originally posted by Dj Perico: Thanks Logan I just go there when I go to Va Beach. Millennium Autosports This place right here do good work they did a couple of my friends rides. So I might check them out also.
no problem looks like a good shop keep us posted on your project, mine is staying under wraps for the most part till I finish. If I can keep up the rate I am at now a month.
Posts: 2,542 |
Boost is boost.
svt coulda used some kinda forced induction to get the power up does't mater haw aslong as its reliable
Posts: 1,687 |
The thing is SVT doesn't like Turbos. If it were to have FI it would have been with a supercharger. Period. I still congratulate SVT on attempting to create NA performance for once...
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by MAYBE aliasfriend: Originally posted by LocoSCZ: Originally posted by Wulfen: A supercharger will take you about 40hp just to make it run with an I4. The turbocharger will use lost power from the exhaust, more efficient that way.
Boost is boost.
Thanks...I tell people time and time again. I have over 138k stock engine, stock trans with the addition of a trans cooler and that is IT!!! It outlasted just about every or any other Tour that has been modified. Can't argue with results.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,224 |
Originally posted by LoganB: Garrett T28 powered. It's not done yet but I am getting there I think with about 3 weekends of me being home and not here at college and yeah another one is done. Hurry up we need to go cause havoc to the SVT's.
Are you using a T28 or a GT28 dual ball bearing? I wanted to go GT28 but couldn't justify 3x the cost of my T3 Super60.
Unless I can cough up some cash quick, it looks like my turbo project may be put on hold until spring.
You've gotta post some pics when you're done! BTW, what did you do for a header?
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 869 |
Originally posted by ButtonPuncher: Originally posted by LoganB: Garrett T28 powered. It's not done yet but I am getting there I think with about 3 weekends of me being home and not here at college and yeah another one is done. Hurry up we need to go cause havoc to the SVT's.
BP
Garrett GT28RS Disco Potato COMPRESSOR SPECS: TO4b HOUSING .60 A/R HOUSING 62 TRIM COMPRESSOR FLOW: 35 LBS/MIN TURBINE SPECS: T25 .86 A/R HOUSING 76 TRIM 54mm GT SERIES WHEEL Dual Ball Bearing Center Section
Right off the site, as for the headers I am going to use the ZX tuners and mod those for the turbo or head on down to my buddies at True Blue Performance, the reason I posted about them before is the owner is a family friend. So if all else fails drop the car off there and let them have at it. But this weekend I have to finish the atx to mtx swap
Also for a boost controller how about this one?
Here
Finally, BP how are you doing on your project over all last time you posted looked pretty much done correct?
Posts: 495 |
What destroyed? Boost is boost. If anything a turbo is better since, a properly sized turbo makes it's boost in the low rpms where the stresses on the rods are less. Superchargers don't make full boost till the upper rpms where the stresses on the rods are much worse.
Here's the 3 main things. Proper tuning, proper maintenence, and proper driving. And even with just proper tuning and maintenence, it can wistand some hard driving. There's a guy on the Focaljet with a turbo'd focus doing 9psi non-intercooled and he does a lot of track days and the car's fine.
The Zetec is actually prettty sturdy, but the SVTF's higher compression makes it harder to get more power out of it even though it's flow is pretty good. The problem with the SVTF is it had more HP but it also had more weight so it was only slightly faster. The stock Focus chasiss is already real good so just add the SVTF suspension which goes for around $300 for the set, and turbo it and it's good to go.
Wanting to add a SVTF engine isn't worth it unless you can get a whole engine and wiring harness and ecu for $1000 or less. Otherwise it ain't worth it.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
