Page 1 of 4 1 2 3 4
8
864X4 Offline OP
Just wanted to know what you guys do while seating at stoplights. Do you sit at a stoplight with the car in gear and the clutch pressed in or do have car out of gear and the clutch pedel up? Which is better? Any opinions?
1998 Contour SE V6 MTX-75 Mostly Stock 1986 Ranger V6 4X4, the only mod: weight reduction by rust.
i just sit with the clutch in, and in gear so i'm ready to go when the light turns green...
there really is no "better" method, it's more of personal preference. i'll sometimes do it the other way too, if i know the light is a longer one.
I spin the wheels until the light turns green.
2000 Contour SE Sport Originator of the Beowulf Headlight Mod and the Beowulf CAI
When I learned to drive, I was taught to keep the clutch pressed in when stopped. However, now I sometimes just take the car out of gear instead, so when I drive I use a combination of the two.
E0 Silver Frost CSVT #3095/6535 Alpine CDA-9851
I've heard that keeping the clutch in can be hard on the throwout bearing. However when I'm at a stoplight I usually keep it in until there are a few card behind me.. I've been rear-ended 4 times before, so I'll trade off some possible wear on the TOB to be able to quickly get out of the way!
'99 Contour Sport V6 MTX
O
O
about 95% of the time im out of gear with the clutch out...
im out of gear to keep the leg rested for those times you never know when some fag ricer will want to get blown away...
its your pref
05 Chevy Colorado z71 4x4 *for sale* 97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked) 97 Honda Accord 4 door 03 Eclipse GS
hasn't there been 1,000,001 posts about this already?
Online Content
Same - because usually I coast in neutral to stop. Techically illegal, I believe (coasting in neutral), but old habits die hard.
In a standard vehicle, of course. The Contour's ATX is no fun.
when im at the stoplight i pick my nose
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
Page 1 of 4 1 2 3 4
