Posts: 6,791 |
Originally posted by SVT3Rivieres: you should not ground on the rear deck cause its could be a flotting ground
Please elaborate... Anyone...
Posts: 6,700 |
What he means is, the rear decklid is a "part" welded to the chassis. You are likly to not get a good positive ground. Similar, if you will, to runnning your ground to the actual external antennae. True, it's connected to the body, and it will ground, but it's not the most efficient.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 785 |
yep its what i what to meant. sorry something my term are not alway accurate in english
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 6,700 |
Originally posted by SVT3Rivieres: yep its what i what to meant. sorry something my term are not alway accurate in english
I've heard the term "flotting" once.... yep, just once.. and it was today, too.
I did know what you meant, though.
Posts: 1,287 |
wow, i come back from getting my haircut, and chad has like 5 new names.
Posts: 2,978 |
I grounded both my amps towards the back of the car under the carpet when I pulled that out.
Posts: 6,700 |
Originally posted by ZetecChris: wow, i come back from getting my haircut, and chad has like 5 new names.
What more would you expect?!
Posts: 1,279 |
Well if you had an SVT the power antenna mount is perfect. Also self tappers are not the best route, effective and quick. But a nut, bolt and lock washer are hard to beat. Almost every car as a lip on the inner fenderwell you can mount to.
Previous Owner of 00 SVT Contour #1077/2150
95 Contour SE '01 3L
Posts: 4,714 |
This is what I did, though I won't say that it's the best place/method. It never gave me problems for the 2 1/2 years I had that setup. Unfortunately I just found out last night that the buttpirates that stole my system somehow managed to wreck the terminal.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 951 |
I ground on the taillight.... but you can ground on the back seatbelt Originally posted by hetfield:
Where did your sub(s) go in this setup?
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
