Posts: 1,287 |
where do you guys have your ground wire at?
Posts: 6,791 |
Drilled a hole through a piece of metal at the top of the trunk. Slid the ground onto a bolt and secured it very tight with a self penetrating nut!  (The nut digs into the metal when tightened down)
Posts: 1,287 |
Posts: 6,791 |
To be a little more specific, by trunk. I mean the area under the rear deck lid. Also always make sure that you have bare metal to ground to. I'll take a pic if ya need
Posts: 6,700 |
Bbhind the seat under the side carpet is a "channel" of metal that sticks out, I used a 1/2"x1/4" self tapper and put it there. Be sure to use a ring terminal. DOing ti here will allow you to run the ground under th ecarpet and completly out of view.
In this same channel, there are already several pre drilled holes, which would allow you to just use a machine bolt and nut instead if you don't want to go through the trouble of drilling a screw in there.
Locktight will be a good buddy, too and defently do a bit of sanding to guarantee a perfect surface for grounding.
Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 6,791 |
Originally posted by Stry-ped: Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
Mine is right in the corner so it also tucks behind the carpet. Not to be seen! Its easy and it works...
Posts: 6,700 |
Originally posted by RawBurt: Originally posted by Stry-ped: Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
Guess it would have made more since to not put it right in the dead center, lol.
Posts: 6,791 |
Originally posted by ã??ã¾ã®ã??ã???: Originally posted by RawBurt: Originally posted by Stry-ped: Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
Either way, there are a million places in the trunk for the ground.
And OMG stry-ped turned himself into a symbol!!!
Posts: 6,700 |
Originally posted by RawBurt: Originally posted by ã??ã¾ã®ã??ã???: Originally posted by RawBurt: Originally posted by Stry-ped: Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
Formally known as Stryped!
It's actually striped in Korean... but Shhhhhh, it's a secret!!111!!11
Posts: 785 |
you should not ground on the rear deck cause its could be a flotting ground, under the mat should be perfect and the best, if you want to work hard, the back seatbelt bolt
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
