Page 1 of 3 1 2 3
#1390866 09/20/05 04:57 PM
Z
Z
where do you guys have your ground wire at?
#1390867 09/20/05 05:10 PM
Drilled a hole through a piece of metal at the top of the trunk. Slid the ground onto a bolt and secured it very tight with a self penetrating nut! (The nut digs into the metal when tightened down)
#1390868 09/20/05 05:20 PM
Z
Z
thanks robert
#1390869 09/20/05 05:28 PM
To be a little more specific, by trunk. I mean the area under the rear deck lid. Also always make sure that you have bare metal to ground to.
I'll take a pic if ya need
#1390870 09/20/05 05:29 PM
Bbhind the seat under the side carpet is a "channel" of metal that sticks out, I used a 1/2"x1/4" self tapper and put it there. Be sure to use a ring terminal. DOing ti here will allow you to run the ground under th ecarpet and completly out of view.
In this same channel, there are already several pre drilled holes, which would allow you to just use a machine bolt and nut instead if you don't want to go through the trouble of drilling a screw in there.
Locktight will be a good buddy, too and defently do a bit of sanding to guarantee a perfect surface for grounding.
Rob, I used to have mine grounded there, but I cought a bag of grocerys on it once, and my hand another time, and my head once....
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1390871 09/20/05 05:37 PM
Mine is right in the corner so it also tucks behind the carpet. Not to be seen! Its easy and it works...
#1390872 09/20/05 05:41 PM
Guess it would have made more since to not put it right in the dead center, lol.
#1390873 09/20/05 05:42 PM
Either way, there are a million places in the trunk for the ground.
And OMG stry-ped turned himself into a symbol!!!
#1390874 09/20/05 05:45 PM
Formally known as Stryped!
It's actually striped in Korean... but Shhhhhh, it's a secret!!111!!11
#1390875 09/20/05 06:14 PM
you should not ground on the rear deck cause its could be a flotting ground, under the mat should be perfect and the best, if you want to work hard, the back seatbelt bolt
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
