you havent seen any... because the Duratec has no timing belt... it has a timing chain. Its rare that it has to be replaced, but IIRC there was a recall on the timing chain, or something related to it.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
What exactly is the problem thats goin on? Maybe if you describe your symptoms we can give you a had... that is if you are having a problem...
TEIN H.Tech Springs
Also the TSB was for the 95. It was corrected from the factory after that. If you have some chain rattle, the TSB in interesting information, but since the revised tensioners were installed after 95, don't expect it to solve problems for later cars.
