Posts: 9,602 |
Originally posted by ZeroHour: Originally posted by DemonSVT: You mean quasi-dual.
It's just for looks.
I dunno if its just me, but I thought putting on a catback gave around 8hp increase?
Adding a "second pipe and muffler" to a single exhaust system (i.e. quasi-dual) is just for looks. The second pipe and muffler do nothing but add weight and looks. (i.e. balanced rear view in the SVT's case)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,119 |
Well I have to trust Demon.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 6,910 |
Originally posted by DemonSVT: Originally posted by ZeroHour: Originally posted by DemonSVT: You mean quasi-dual.
well I am not 100% sure but I saw a power increase when I put SVT exhaust on my car, that along with the airbox and optimized y-pipe (where most of the power came from) was maybe 8hp together. I can 140 Hp on a mustang dyno with the airbox and the FSVT 17's. second time I got 154 standard correction on a dynojet after adding the optimized y-pipe, SVT main cata nd SVT exhaust and a drop in K&N
its got to help some, but most likely not a whole lot
- 95 Mystique LS - Zetec/5spd
Posts: 2,116 |
After I put the SVT exhaust on my car it pulls a little harder up top.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 7,117 |
True, but replacing that horrid resonator with a proper straight through design will help a little on the top end, as will a modded Y. Along with a good intake system upgrade, you'll get the punch of a few extra HP.
I've put an SVT exhaust on 2 V-6 Contiques now, & replaced the res with a Magnaflow 5x8 on both of them. More free revving up top for sure. HP increase? - likely yes, but not measured. I do mine for the sound & the looks...
Posts: 9,602 |
Every one is missing the point.
You will get the same gains (if not "technically" a hair better) from a well made single exhaust compared to a well made quasi dual exhaust. (i.e mandrel bent & straight through mufflers) Plus it will weigh less.
That's not an assumption, not a guess, but simple fact.
Comparing an SVT exhaust to stock is not comparing two a like exhaust systems. The SVT uses bigger single piping then stock for starters. Also since you are using stock POS baffled mufflers then half the airflow through 2 is probably a touch better than all of it through 1. That's because of how terribly restrictive baffled mufflers are and Not because adding a second pipe adds power.
2000 SVT #674
Posts: 363 |
Originally posted by brapple: well I am not 100% sure but I saw a power increase when I put SVT exhaust on my car, that along with the airbox and optimized y-pipe (where most of the power came from) was maybe 8hp together. I can 140 Hp on a mustang dyno with the airbox and the FSVT 17's. second time I got 154 standard correction on a dynojet after adding the optimized y-pipe, SVT main cata nd SVT exhaust and a drop in K&N
Unless you go back to the same dyno, that comparison is worthless.
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 661 |
Maybe he is doing it jsut for looks, who cares!
Fast Cheap reliable
Pick two
CEG road warrior
CEG road warrior
Posts: 17,248 |
It will sound/look good. ![](/ubbthreads/images/graemlins/wink.gif) Just do it.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 4,760 |
Originally posted by LocoSCZ: It will sound/look good. Just do it.
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
