Posts: 1,224 |
I went a little nuts and picked up a 255lph Walbro fuel pump. To those that have done the upgrade, what does yours sound like? The sound on mine varies at about a 2Hz rate. The fuel pressure also varies about 1psi at the same rate. It is WAY too loud so I'm going to get a 190lph unit and swap it out. I knew it was overkill.  Do you think that the change in pitch/pressure is because this unit is just way to big for my system? Or is there something wrong with the unit itself? BTW, I also have an Aeromotive FPR. Thanks, Ben
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 5,810 |
They are all noisy.
When you have a full tank you don't hear it. It is only when you get down to about 1/4 tank that it sets up a good whine. I monitored the fuel pressures with it on my system and the fuel pressure regulator still regulates to 45psi at idle, just like stock and 55psi wide open throttle. I can't see it being too big for the system if the pressures are still being where they are supposed to be. If it was too much the regulator would be wide open and the pressure at idle would be higher than 45psi. THEN you would have to change it. If you don't need that much pump then don't used it. Are you return style or returnless. I didn't look at your info.
See My Mods
Posts: 1,224 |
I'm return style. '96 Zetec. I'm bulletproofing my fuel system before the turbo upgrade.  BP
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ButtonPuncher: I'm return style. '96 Zetec. I'm bulletproofing my fuel system before the turbo upgrade.
BP
Really didn't need a 255lph pump though!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,224 |
I know.  Originally posted by ButtonPuncher: I knew it was overkill.
I'm going to swap it out with a 190lph when I have the cash.
BP
Posts: 495 |
Why do you want to swap out something smaller? A 255 Walbro isn't unheard of for custom setups on the Focaljet. How much HP do you want?
My exhaust is fully 3" and that's overkill for my setup, but no way am I going to downgrade to something smaller. Granted if I had to do it over, I probably wouldn't go that big, but what's done is done. And I guarantee my exhaust is louder than your fuel pump.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 5,810 |
If it works, just leave it. Things will be getting louder with every upgrade as Seawulf pointed out.
See My Mods
Posts: 1,224 |
Actually, now that I have the body gasket back in, it's not too bad. Once I have the rear seat bottom back in, it should be pretty tolerable. I'm shooting for no more than 200WHP with my current near-stock Zetec/ATX combo. I figure any more than that and I'm asking for trouble. I'm going to try to limit myself to around 6psi as my daily driver. ...even though I have a spare motor and tranny.  BTW, I also have a 3" exhaust. My friend with a '69 Camaro laughed his azz off when he saw this... As with the fuel pump, it's overkill now but will be perfect when the turbo is on. Thanks guys. Later, Ben
Posts: 495 |
Ooh, very nice.
Personally I think even a stock fuel pump would be good for 200whp. That's why you put in 42lb injectors, so you can keep the fuel pressure stock, but yeah keep it if you've got it.
I'd be more worried about the ATX. But totally stock the Zetec can do 200whp easy. If properly tuned.
Posts: 5,810 |
that 200 will turn into 250 pretty quick if he tunes it right!  I know the addiction of power. As soon as someone takes you its over.
See My Mods
