Posts: 101 |
Today I dynoed my car and tryed to tune my safc. I am not sure what these #'s should be at but take a look and let me know your thoughts. Red is after trying to tune it blue is the baseline any help would be appreciated particulary on why it is so peaky (i know i use all the technical language)
1998.5 SVT Contour
silver frost
Intake, Exhaust, 20% mirror all around,
18" ALT stanima wheels, Eibach's,
B&M short throw, 9mm ford racing wires,
SAFC II, oem carbonfiber hood, MSDS headers,
Panasonic head unit and one alpine 10".
Posts: 1,860 |
Ignition issue. Plugs, wires or coil pack. It looks like you are dropping spark.
On top of that it looks like your knock sensor is screwing you. See at the top how it seems to just pick up a ton of power. That's your timing coming back.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 101 |
how do i fix the timming issues? It doesn't show that i am knocking on my safc. With the ignition issues do you think that could just be fouled plugs?
1998.5 SVT Contour
silver frost
Posts: 1,194 |
For all of the mods you have, that is very low. You should be around 180fwhp. As mentioned before, check your plugs, wires, and coil packs. Any CELs thrown? Hesitation maybe?
Posts: 5,600 |
Those are some sad numbers! FWIW, with similar mods to you (no tune) I dyno'd 175whp. My graph looked similar to yours, just not as bad (it also seemed as though I had possible spark/knock issues). I have since cleaned the manifolds and gotten some magnecors. Havent been back on the dyno since to see if it fixed it.
Black 1998.5 CSVT
Posts: 1,978 |
Did you have the headers for that run chris?
-Alex
Alex
'99 SVT Contour
Posts: 5,600 |
Yup. I was hoping for better, but you can see how rich Im getting up top. X-Cal 2 is next on my list. Im going to make 3 more dynojet pulls to see if Ive corrected whatever problem I was having, and also to get a more recent look at whats going on to send off to ADC. Hopefully I can get up into the 180's.
Black 1998.5 CSVT
Posts: 1,860 |
12.0 isn't that rich on a duratec. I tried everywhere from 13.5 down to 11.5. From 12 to 13 there isn't that much of a difference. It could be leaned a touch but you won't go 'Holy shirt this is better' at 12.5.
Whatever the issue it's mechanical. My guess is the coil or a wire is arching. All of your grounds are good right?
2001 Lincoln LS8
1994 Lexus GS300
Posts: 101 |
No i havent checked the wireing. To be honest I dont really know what to look for and yes there is hesitation. Does anyone know of a good place to go in the kc/lawrence area that would be able to help me?
1998.5 SVT Contour
silver frost
Posts: 1,860 |
Let's start over....Have you ever changed the spark plugs or ignition wires? You don't need a mechanic to do this.
2001 Lincoln LS8
1994 Lexus GS300
