Page 2 of 3 1 2 3
#1388208 09/17/05 07:19 PM
F
F
For your subs, I'd give Blaupunkt a try for your amp.
Blaupunkt PA2150 $90 shipped! 400Wx1 RMS
#1388209 09/17/05 07:54 PM
You can try this website. Amps
1999 Ford Contour 2.5V6 5peed Se Sport. Aim djperico Looking for svt front and rear bumpers.
#1388210 09/18/05 01:26 AM
Originally posted by 96tourkid:
This looks ok...but "It's GInormous"
[url=http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13893]
Hardly
Length With Shroud: 11 27/32"
Width With Shroud: 10"
Height With Shroud: 2 1/2"
the amp in the picture looks like a Kicker 04KX850.4 which is a 215W x 4 amp. and something like 22" long. roughly twice the size of the one your actually thinking about getting.
the one your looking at actually looks like this:
And remember, alot of the size of this amp is actually just the wire shrouds
Hifonics is actually a really good brand but some of the other amps built by Maxsonics from some of the companies that they bought out such as Crunch flat out suck though.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
#1388211 09/23/05 12:10 AM
9
Carpe... Well I went with your Kicker name. Not as much power. Got it for $100 from a friend here on campus.
http://www.crutchfield.com/S-VS129hRmUPv/cgi-bin/prodview.asp?i=2064KX3504
Looks like it'll still do the job.
Only thing is I have one set of rca's coming from my HU.
And there are spots for 2 sets. What exactly does that mean...
#1388212 09/23/05 03:33 AM
a 4ch have front and rear input. if you dont use two RCA from your HU you will not be able to use your fader.
In many case some amp have also a output to add another amplifier without passing another RCA from the HU (its a passthrought, not affect by the crossover or the gain)
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
#1388213 09/23/05 05:17 AM
9
I'm sorry but I don't understand what you are telling me...
I have a indash dvd player. (no preamp outputs) it's connected to a 7" screen. My RCA's are running from the outputs on the back of the monitor, to my 2 channel amp (which I sold) And my left and right speakers were combined and then powered from the amp. (Yeh, I know all of you SQ buffs say it's dumb and that's fine.) But my rear left speaker wire is fried or something. And I have no clue how to run new wire through the car to it. Plus that would involve pulling out my in dash/monitor ultimately ending in a large@ss amount of unnecessary.
So I'm used to not having a fader, I can deal with that.
So are you telling me I can't use all 4 channels of the amp?
I originally planned on powerin my components (all 4 sets, the doors) with "amp 1" the front left and right channels. Then bridging the "amp 2" to run my polk sub. So is amp 2 not gonna have any signal running to it since I only have one pair of rca's?
If so can I buy a splitter? (yes i know it kills the signal and what not)
#1388214 09/23/05 11:32 AM
If your using this 2nd amp that you bought to run your sub, why did you buy a 4 channel as opposed to a 2 channel? Confused
Nevermind, just saw your original post stating your replacing your old amp and only want to use this one to run the whole system.
Vinny 2000 T-RED CSVT MODS: 18" REV model 2 ST200 struts/Roush springs CTA intake Pipe/K&N Filter Dtec Heatshield Optimized TB True Duals w/ magnaflow mufflers/resonators
#1388215 09/25/05 07:39 PM
9
So with one set of rca's, can I still use the front 2 channels for my components and bridge the back 2 for my sub?
#1388216 09/25/05 09:09 PM
with one set you can only drive your front channel, you will need to split your RCA for the rear channel (bridged for the sub)
#1388217 09/26/05 12:11 AM
9
That'll hurt the clarity of the signal won't it...
Oh well.
Page 2 of 3 1 2 3
Moderated by  dnewma04_dup1
