Posts: 5,345 |
Originally posted by Ike: Well, I'm glad everybody except for me is a mechanic.
"When my ATX had the 60k tune-up, it cost me about $700 but that included a host of other things which was suggested and I said yes to."
I take it you did not read my post.
1996 V6 ATX 96K miles
Posts: 1,130 |
I will do it for you if you are willing to drive to Tampa.
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 7,100 |
a little thicker skin will help you, Ike. He's an Aussie... that means he may be right, but he'll tell you the wrong way.  Seriouly, though. Everyone starts somewhere, and a tuneup is a basic means of maintenance that you can do. There are AMPLE how-tos for the duratec (look under Duratec Maintenance in the FAQ pinned at the top) ALL of which are doable at home. Ray
'99 CSVT - Silver #222/276
Posts: 4,760 |
Ike were are you located...Maybe a Ceger can help ya out.
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 5,345 |
Originally posted by Ray: ... He's an Aussie... that means he may be right, but he'll tell you the wrong way.
Ray
LOL. This is even better.
Er...Just in case some don't get it (right, left, right, wrong).
Posts: 4,693 |
I can't blame your buddy of being shy about changing the plugs after trying to work on that Mopar.
If it was anything like the 98 Dodge Grand Caravan that I worked on last week for my brother in law, that would be enough to make anyone think twice.
It has a 3.3 litre engine which is a pushrod OHV V6. The front plugs are very easy. The rear plugs require removing the upper intake manifold. To get the upper intake manifold off, you need to completely remove the windshield wiper system which is in sort of a tray above the engine. He paid me well for the job, but I may not have volunteered to take it on if I would have realized what I was getting into.
The Contour is very doable. I can't see even a novice taking more than 2 hours. Those that are exkperienced can do it in about 1/2 hour.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,506 |
If you want volunteers to help you out (perhaps in exchange for a few cold brewskis) or to refer you to someone nearby who is affordable, you might have to (gasp!!) tell us where you and your car are located. If Tampa FL doesn't work for you, how about Portland OR?
Do you want help? Or do you prefer to bbitch?
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 265 |
I too was "afraid" to do my own tune up on my 96 SE at first until I read all about it here on CEG. Sure it took my 17 yr old son and myself a little while to do, but now either of us could do it in about an hour (with breaks). Hardest part really was getting the old plug wires off. You just have to pull alot. One tip I did read about was using a 8"-10" length of 3/8" rubber hose to place the new plugs in to ease lowering them down to the head to get them started. Other than that you need basic tools, i.e. rachet, socket, extension(s). Like everyone else has said, give it a try and if you run into trouble ask for help here. You'll feel really proud afterwards by saving all that money and learning something in the process.
Posts: 129 |
Now THAT'S what I'm trying to hear. Anyway, my first car was a 1976 Ford Elite. No front-wheel drive, no fancy stuff, and LOTS of room to work with under the hood. 4 plugs and wires on one side, 4 on the other. Pull 'em out, plug 'em in. Simple job. Of course I didn't have anything to lose working on an old clunker with a 351 iron block. I've never even messed with a front-wheel drive car before, and after watching my boy Sean work on my Chrysler Cirrus (Mitsubishi engine actually), I don't want to screw anything up. That's alright, it's time to call my pops back into town and have him show me a couple more things.
Although I don't think he's going to be to thrilled about it either (he hates these new cars).
'98 CSVT Black
-AEM short-ram intake
-Optimized TB
-Optimized y-pipe
-Magnaflow cat-back
-B&M short-throw shifter
-UD pulleys
-Poly mount
"It's quicker than it was stock!"
Posts: 6,700 |
Ike where are you located?  I've changed an ample amount of plugs and wires for CEG'ers in Southeast MI and would be willing to show you the roots.... not if you are 3000 miles away, though.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
