#1386918 09/15/05 04:43 PM
butane Offline OP
How do you read codes on a 95 ford contour? do i need the special hand held computer for this? Can i buy this from somewhere?
where do i hook it up? and where do i get the code listings?
I miss old school cars...ggrrrr
#1386919 09/15/05 04:48 PM
#1386920 09/15/05 07:53 PM
Z
Z
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#1386921 09/16/05 07:55 PM
butane Offline OP
does autozone pull out codes for free?
do all locations have it?
do you get a print out for this?
#1386922 09/16/05 08:00 PM
Most, if not all, will pull OBD-II (96 and newer models).
I think I read of a post where OBD-I (95 and older models) was done too. If they do it, it is free.
No, they don't provide a print out. You should "hover" behind to read the codes with them and record it.
#1386923 09/16/05 08:14 PM
It's so easy to pull '95 codes, it's hardly worth the drive to Autozone - even if they do know how to pull pre-OBDII codes.
Note that the dalidesign.com site has gone off line - but you can find the original pages of interest through web.archive.org.
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
#1386924 09/19/05 01:03 PM
butane Offline OP
my contour does not have a cel light! i am not sure why i havent seen it ...maybe a blown bulb? is there anywhere else i should look for it apart from the dash?
#1386925 09/19/05 01:19 PM
Before you start pulling out the instrument panel, start by checking two items first. When you turn the key to on, the CEL (yellow) should come on and then go away after a few seconds (when it is cranked). In addition, you may want to check that Fuse No. 11 in the Engine Compartment Electric Distribution Box (next to battery) is not burnt out or missing.
