Posts: 179 |
The Zetec can use 100hp runs of nitrous as long as you upgrade your fuel pump(the stock piece runs out of steam REAL QUICK), run colder plugs and get a custom burn for timing retard for the nitrous use. I would either run a multi-port setup or a dry kit seeing as the Zetec has a gigantic loop in the intake that allows the fuel to seperate from the intake charge. This makes a standard wet kit VERY iffy to use. All of this and you could have an extra 100hp on tap for about $750 if you shop right with no damage to the engine. If it runs lean with ANY power adder you will break stuff. The stock engine is good to about 225hp before you start to break internals. Anything more and your living on borrowed time. The only inexpensive way to turbo a contour/mystique is to do it yourself. There are PLENTY of threads on here about turboing the Zetec. Good luck and welcome to the board.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
Posts: 2,483 |
I've run 100HP shots through my car, it can be done.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 253 |
Could a 7psi eagle talon turbo fit????
Well snow is coming!!!
Can't wait to do some snowboard...
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Seawulf:
Easiest way to go FI is to do what LoCo did and buy the Focus JRSC kit and install it. The only problem is it won't get you anywhere near 200whp without serious mods.
Working my way there.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 495 |
Most OEM turbo's for 4 cylinders will fit. I'm using a WRX turbo. You'll probably have to re-clock the turbo to get the inlet and outlets to point where you want them. The hardest part is making the exhaust manifold, but using a stock Focus header with a small adapter plate/pipe is a good alternative.
The main problem with stock OEM turbo's is they will run out of breath past 9-10psi. At 7psi I did 190whp, and at 9psi I did 200whp, not a huge difference. But if you just want a easy 200whp with quick spool, coupled with the low cost of buying one used, they're a good buy.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 253 |
Thx for the info.  Another thing... Could you show me some pics (if possible) And give an idea of the prices. Plz...
Posts: 495 |
http://www.focaljet.com/ubbthreads/showflat.php?Cat=0&Number=2416664577&an=0&page=0#2416664577That's the link to the Focaljet FAQs for FI. Lots of good info and the Focaljet is where I learned everything I know about the Zetec. While the Focus Zetec isn't exactly the same as ours, it's close enough that 99% of the info crosses over. This is the link too the google cashe of a turbo FAQ I wrote for my Cougar forums. A forum shutdown wiped out the main FAQ so this is all I have right now. Only the first page is avaliable. Google Cache link
