I did it! easier then I thought it would be..I mounted a set of PIAA 510's onto SE brackets, they are really different then the SVT ones but I managed..heres what I did..
Heres what I started with..
TOOLS NEEDED - a 3/8 drill bit
- 3 hours
- dremel or a sawzal (spelling?)
- phillips screwdriver
1 You need to take the stock lights outa the brackets by removing the adjuster screw from the bottom, once you screw it out, the spring comes out and all you hafta do is just losen the sides and the foglight will pop outa the bracket..
2 Next up I lay the PIAA light onto the bracket to get an Idea of where I hafta drill my hole so that I could bolt it into the bracker but first you hafta shave off the plastic piece that kinda acts as a support..
rough Idea of what I had to do..
![](http://goonz12.zoto.com/img/original/c9d52413cdfa3fced3780ae5ed355a5e-.jpg)
Here is the part I mentioned where you have to shave off that support piece..
before..
![](http://goonz12.zoto.com/img/original/588ac24b4eea35989fd57da1ca8a6e0c-.jpg)
After
3 Now comes the part where you hafta drill the hole and bolt the PIAA onto the bracket, it wont be easy getting the PIAA in because the bracket isn't meant for the PIAA, it will take time but as stated, its never gonna be a perfect fit..I got mine to lock in and hopefully it wont move here and there..heres the finish product
This Howto should be used as a reference or a guide, whatever you wanna call it. If somthing goes wrong, dont come blamming me and I will not be responsible if somthing were to go wrong..
ANY QUESTIONS OR FEEDBACK, PLEASE PM ME!
