#138471 11/05/01 11:14 PM
I
Ibsen Offline OP
I
So, I finally got it done.
My car was originally only with the speedo cluster, but now I have the one with a tacho instead.
I had one problem, an that was that the fuel gauge worked inverted full=empty!
After wainting for some time, I got the in-tank pump/sensor from the donor car, and upon installing this everyting works fine now...
The sensor did send an inverted signal....!!!
Partnumbers were also different:
Original: 97BP-AA
New: 98BP-AA
So anyone doing this mod: get the tank unit also, as your own might not work properly with the new cluster...
'97 mkII 1.8 sedan, mtx, Diamond White, Magnecor KV85, clear side repeaters
For some reason, I got the craving for a taco supreme from Taco Bell when i saw this topic. Tacho Grande!
Fsck, now I'm really hungry.
damnit man
now i want a taco!
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
"Drop the chalupa :p " and then give it to me!
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
Hmmm... 10 pack of soft tacos with fire sauce...
aaaaaaagagghghghaghhhghghgh... *drool*
Me and my co-workers just went to Taco Bell today for lunch...what a coincidence.
97 Black Contour Sport V6
KKM Induction; Pioneer CD player; 4 Kenwood 5"x7"; 2 Rockford Fosgate 8" Subs; PIAA 9006 Lights.
Uhhhhhhhhhhhh...anyway...ON Topic
Thanks for the info. I had the same problem some months ago when I tried swapping gauges from a 98 Mystique into my 98.5 Contour. Only had a couple problems that made it non feasible. It was kinda cool though, having the fuel read backwards. Your car actually gains gasoline as you drive it. laugh Pretty cool.
I do have a couple questions if you don't mind.
First, what did you do about the odometer? I assume they were different.
Second, does your Cruise Control work still?
TIA. laugh
I
Ibsen Offline OP
I
Well, I have a bad habit of buing cars without ANY extras, This is actually the only extra in it. smile
Since it is only a 1.8 Zetec, u cannot buy cruise control as factory optional.. frown
Odometer? I didn't do anything.
The 97 model of the mondeo has an electrical odometer, so when I ordered the cluster from the wrecker,I just asked for an electrical version.
It has not been adjusted to show correct mileage -yet, I'm still thinking about a way to roll it forward without dismantling it....
I have done that on older Ford odometers....
Does anyone know what type of signal the odometer gets from the ECU?
Btw the meter internals looks as the older version I had in my 1985 ford..., except for the fact that there is an electrical motor to drive the clock and another electrical device to move the needle.
Dont know about the cruise problem, but it really sounds strange that the cruise control should be affected by the instrument cluster...???
