Page 3 of 6 1 2 3 4 5 6
[IMG]C:\DOCUME~1\atroiano\LOCALS~1\Temp\MXLibDir[\IMG]
98.5 SVT FOR SALE $5000
Sorry, didn't work. Let the flaming begin.
I see no reason it wouldn't apply, though I can't speak specifically, as I am not sure.
You're still in a gear... you're still loading the engine down if you coast in that gear... so shouldn't it still shut off the injectors?
Unless the ATX just lets it "free-spin" when it senses the engine load, etc.. As I said, I am not sure, but I would imagine the same results.
Ray
Originally posted by Ray:
Unless the ATX just lets it "free-spin" when it senses the engine load..Ray
Okay, understood everything you said until this. This went over my head. Maybe I need to get lunch as the old grey cells ain't working too well now.
I dunno.. Torque converter disengaging the transaxle, or something. (not an ATX guy)
Ray
I'm tryin not to let the secondaries open up as much, if it can be helped. I do go above 4000, but not for as long as I used to (don't want carbon build-up). My last tank was about 27.5 mpg, but I don't like drivin' like a grandma to get it, LOL.
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
In neutral, you are still pumping gas through the injectors (idling)... in gear, it will actually shut off the injectors and stop using gas at all.. Coasting in gear is the most efficient means of operating the engine that is possible.
No kidding? Wow, that's good to know.
I've been coasting a lot in neutral recently, there are lots of hills around here. I find I can coast a significant percentage of my drive to work (like maybe 20%?)
To add another twist to the neutral question, if you coast in gear you'll go slower and have to get back on the gas earlier. If you coast in neutral you can go quite a bit further and faster. But how much gas does idling use?
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
A full tank can idle (from full to empty) for about 10 hours. Of course, this was in a Lincoln Continental that was left running at the airport long-term parking.. but still.
Ray
OK how would the MTX computer even know whether the car was in gear or not? I dont know about ATX but this sounds false to me ...
Maybe .................. Neutral Position Switch?
