Posts: 9,872 |
Originally posted by teamSVTour: Originally posted by Stazi: Haroon, I would seriously relocate those lower brackets as the stress the Mirko is under will slowly cause the paint to start crazing which will suck!
Staz, can you explain what you mean a little better? How should we have these brackets installed for a proper install? I'm still waiting for mine to get here but when I do I want to have a proper install.
thanks
I know what he means..the three metal brackets that came with the spliiter arent alligned properly onto my mirko causing some tension spots. I will rectify this problem as soon as I can..I planned on it sooner or later..thanks for the heads up stazi
I wish they came like pre-drilled, make life easier..
Posts: 9,872 |
got my first chip today..pissed but ah well, better then what i expected it would be..im getting a lot of looks now
Posts: 487 |
does anyone elses Mirko need ALOT of body work done before sending off to paint? Mine has some tiny holes in the gel coat as well as needing ALOT of sanding, even the edges (where it touches the wheel well) needs trimmed b/c the fiberglass is not cut straight and extends past the gel coat.
Just wondering if this is normal.
thanks
SOLD Polarg M-28 super bright white bulbs. Replace yellow stock license plate bulbs. See add in classifieds.
WANTED:: EVO style CF hood
Posts: 636 |
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 728 |
I still haven't opened my box yet... I figured I'd do it in the Spring when I install it.
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
Posts: 540 |
Yes, mine does as well. I also noticed that the lip that overhangs the lower part of the facia (bottom of the grill area) doesn't match all that great either - I have about a 3/8" gap on one side, and a 1/8" gap on the other side.
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
Posts: 9,872 |
Originally posted by teamSVTour: does anyone elses Mirko need ALOT of body work done before sending off to paint? Mine has some tiny holes in the gel coat as well as needing ALOT of sanding, even the edges (where it touches the wheel well) needs trimmed b/c the fiberglass is not cut straight and extends past the gel coat.
thanks
mine was really really bad from the edges, i figured I give it a little sanding once i take it off for the winter..which is really really soon
