#1381509 09/08/05 06:16 PM
My bro's got an F-150, and he was asking me about paintin' his rear bumber, which is chrome, to match the body color (white). I honestly don't know what to tell him. Anyone know what all would be involved, ie. sand off chrome, dip it, or what. Any help is appreciated. Thanks
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
#1381510 09/08/05 06:58 PM
The same process as our chrome rings, though much larger in scale... sanding could work, though for failsafe results I would dip it (will require a large container, to say the least..)
Ray
#1381511 09/08/05 07:01 PM
I scraped the chrome off with a knife... it worked fantastic until I busted out the dremel and tried to speed up the process. Dremel sank right on into the some what soft plastic.
#1381512 09/08/05 07:30 PM
What about a wire brush wheel? You know, those really stiff wires (like coathanger style) sticking out from the center, and when you turn on the drill it eats away the paint, etc.. They used to advertise them on the "only on TV" sales... for removing paint from walls, etc..
Ray
#1381513 09/08/05 07:31 PM
Yes, but isn't the front chrome ring plastic/ a chromish plating? I don't think meriatic (sp) acid will take off the nickel plating on the steel bumper. You will need to get the bumper stripped of the chrome. You can have it bead blasted, dipped (only chromers have the resources to do this, not really a do it yourself project). Prime, paint, sand, paint, sand, paint, cure.. then clear it.
2005 Magnum R/T Custom with Suicide doors, audio, hood, etc. 2000 Contour SVT with less than 150 original miles. Putting the "G" back in "Bling".
#1381514 09/08/05 07:41 PM
Sand w/ 320 until COMPLETELY dull (best to use a DA)...prime, wetsand w/ 400 & soapy water by hand being careful not to go through the primer exposing the metal & then paint.
1999 Sportage 4x4...don't go there, it was free ....______o_o .../_l l__\____\ ..|--l l__----[]\|/[] .....................oo =( )_)----( )_)--)_)
#1381515 09/09/05 10:53 AM
Thanks for the info guys, I'll pass it on to my brother. We kinda thought it would be involved like this, but were hoping there might be a shortcut. Oh well, thanks again.
Scott
