Posts: 2 |
Just a noob comment.I bought my 95 tour in 97 with 49000 km
and still have it today along with my 01 cougar and I find
it strange that my diff and tranny has lasted so long with
no problems.It now has 260000 kms on it and has been beaten
with no restraint since day one.the only maintenance I did
to it was change fluid every 3yrs or so with the cheapest
dex3 fluid.My contour isn't modded however.I've started
modding my cougar lightly (svt uim,tb and gmk's stuff)and
when I changed tranny fluid the first time shortly after
I bought it the fluid was brown and burt like I've never
seen on my tour(had a trailer hitch when I bought it,got a new engine under warranty though  )replaced that fluid
with castrol dex5 and has been great since 1 1\2 yrs
despite beeing driven the same way the tour's been.I just
don't like the notchy feel of it and double clutching to
get in 1st gear when moving sorta sucks too but as far as
it beeing reliable I can't complain.
Posts: 3,867 |
Originally posted by todras:
From TH
...As to other aftermarket suppliers who 'say' that their lube meets Ford 'WSD-M2C200-C'...I'd be intersted to see their proof of being 'authorised by Ford'...or do we assume they have been certified and passed all the Ford tests etc from a lube submission...
Here was my email to Royal Purple:
Originally posted by me:
I notice that you list Synchromax as compatible with Ford's XT-M5-QS spec WSD-M2C200-C gear oil for the MTX-75 manual transmission. You are, perhaps, the only aftermarket lube company to do so. I have a 96 Ford Contour with the MTX-75, and I have 3 quarts of Synchromax in the trunk, waiting to go in the tranny. The Motorcraft lubricant is over $21/quart locally, so I was glad to find you. However, I do have a few questions before I go ahead with the drain and fill.
What sort of testing/documentation/certification have you done to ensure that the Ford spec has been met? Is there a "seal of approval" that has to be obtained from Ford? I'm curious why more companies (such as Redline, Amsoil, etc.) don't make specific claims with regards to OEM specs. What have you done that the others have not bothered to do? Thanks for your time and attention, Roger B Wichita, KS
And here's the quick response:
Originally posted by Royal Purple:
Roger,
Thanks for your email regarding the Ford MTX57 5 Speed Front Wheel Drive transmission in your 1996 Ford Contour.
We have tested the Synchromax in this Ford World Car platform in Europe for several years through our Italian distributor. The Ford spec calls for a GL-3 rated gear oil in a synthetic 75W90 formulation. A GL-3 rated gear oil is not really a gear oil at all in that it does not contain any EP additives like you would find in a EP gear oil used in a differential. See the attached API description of GL ratings.
The Synchromax is a slightly lighter viscosity fluid than the Ford product but also contains our Synerlec additive package which gives the oil film 300% more film pressure to resist metal to metal than a GL-3 oil but still allows the synchronizers to function correctly and in this case, more efficiently making for smoother shift quality.
No, the Synchromax is not a Ford certified fluid meeting this particular specification - to do that - it would have to be pretty much an exact copy of it - so it would perform no better. But we are not claiming it is a warranty product, only that we recommend it for this particular application. If you want the OEM fluid in your 9+ year old car - then the Motorcraft fluid is right for you. I suspect that you've upgraded the tires, the shocks, the brakes, maybe the audio system, why not upgrade the fluids?
The reason the Ford Motorcraft product is so pricey - it's not a better product, it's just going through more levels of marketing. The lube blender sells it to Ford Europe (or North America) at a markup. Ford then distributes it to the Different divisions (at a markup) who then distribute it to the District level (at a markup) which then goes to the dealership (at a markup) who then sells it to you at 21 / quart. It started as a 3-4 / quart product with 5 people making 35-50% markup.
Attached is a press release of another Ford application using the Synchromax in a Tremec 5 speed with higher horsepower that I thought you might find interesting.
David
David Canitz Tech Services Manager Royal Purple Ltd 1 Royal Purple Lane Porter, TX 77365
Function before fashion.
'96 Contour SE
Posts: 21,197 |
Wow they actually have experience testing it in an MTX-75! Nice. I'm putting some in a car I'm doing a clutch job on this week. I'll report back on shift quality. I don't know what's in it and I doubt he does either.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,141 |
Originally posted by todras: Wow they actually have experience testing it in an MTX-75! Nice. I'm putting some in a car I'm doing a clutch job on this week. I'll report back on shift quality. I don't know what's in it and I doubt he does either.
I LOVE the stuff.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 5,810 |
What!!! An aftermarket fluid without the the Ford Rating or approval...and without any qualification other than Royal Purple recommends it? Awefully brave there aren't you? I mean, That isn't saying anything more than Redline said but now its good enough?
I'm not saying you are wrong to put it in, just pointing out the obvious questions that a shrewd person reading 400+ posts would have....
See My Mods
Posts: 5,810 |
Originally posted by pole120: Originally posted by todras: Wow they actually have experience testing it in an MTX-75! Nice. I'm putting some in a car I'm doing a clutch job on this week. I'll report back on shift quality. I don't know what's in it and I doubt he does either.
I LOVE the stuff.
Funny.
People said that with:
1.)Fresh ATF 2.)The Cocktail 3.)Redline MTL
What will they be saying in six months to a year when the first trans blows using it? Let me tell you...it will go something like the first 39 pages of this thread.
(something smells like....)
See My Mods
Posts: 636 |
Wow I now have a headache after reading the first 30 pages of this post. So with that said can someone bring me up to date on this post? Has there been any conclusions on this, did those test results ever come back, were they posted?
I think I have come to a conclusion though... I'm not going to run any oil so there!  ...  ...
haha oh so funny
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 9,065 |
poop stinks!
Posts: 3,944 |
Roger,
We have tested the Synchromax in this Ford World Car platform in Europe for several years through our Italian distributor. The Ford spec calls for a GL-3 rated gear oil in a synthetic 75W90 formulation. 1A GL-3 rated gear oil is not really a gear oil at all in that it does not contain any EP additives like you would find in a EP gear oil used in a differential. See the attached API description of GL ratings.
2The Synchromax is a slightly lighter viscosity fluid than the Ford product but also contains our Synerlec additive package which gives the oil film 300% more film pressure to resist metal to metal than a GL-3 oil but still allows the synchronizers to function correctly and in this case, more efficiently making for smoother shift quality.
I really hate to bring this back up, but didn't Terry point out that the EP additives is what he feels was partly to blame for causing all the goo?
Originally posted by TH from FCO post: "...don't get hung up on the viscosity of the lubes here...the MTL appears to have the same additives as a hypoid gear oil that is designed for extreme pressure,which the MTX75 does NOT need. The fact that the MTL carries debris all round the trans appears to be the issue. Just smell MTL and smell a hypoid gear oil...same,then take a smell of Ford XT-M5-QS.... the Ford lube does not come close to the others in smell. This is an additive issue.... and again an MTX75 does not need ANY 'EP' additives as the MTX75 has none of it's gears with a hypoid gear 'cut'. Also woth noting is that an 'EP' lube with a Quaife or Torsen will REDUCE the effectiveness of the ATB diff. An ATB diff balances torque to each side by the friction 'end load' of the spiral cut diff pinions pressing on the diff carrier case. Using an 'EP" lube will reduce the end thrust friction of these pinions on the case and affetct the torque bias...not good."
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 21,197 |
Because they've actually tested it on an MTX-75 and can back it up. On top of Terry recommending it. I listen to the guy building my transmission.
-'96 SE MTX 3L
