Page 50 of 74 1 2 48 49 50 51 52 73 74
#1380349 09/26/05 01:04 PM
Originally posted by warmonger:
So that is your goal? Everyone quit running MTL because you and Terry and mapoftazi say so?
Yep that's exactly what I've been saying all along. You're so astute.
#1380350 09/26/05 05:25 PM
I have some left over Syncromax.....if you'ld like top send that out for testing as well.....
#1380351 09/26/05 06:18 PM
Drom Terry today
...today I opened up a V6 MTX from a customer in
Linden ,Mi,Todd M...99 Contour V6 ,over 100,000 on
it,supect diff(kicking back thru steering wheel,couple
of teeth starting to go on the diff gears),bad 3rd
gear syncro....
This trans was running red ATF....,about 1/3 of the muck on the magnet Vs Petes and the case was very clean,no black stain
X
X
Originally posted by RogerB:
I checked with my local Ford dealer on the Honey, and it's $21.60/quart. I've emailed Bill J today (Friday), but I don't expect a response until next week. Where is anyone finding this stuff for $15?
If you are really in a hurry to get it, Ford Parts Online has it for $12.97 unless I got the part number wrong. XTM5QS right?
Matt 2000 SVT Toreador #1210 of 2150
ya but they make you buy a whole case.
My local ford dealership parts guy hooked me up with a score: $15/qrt. He looked at the price and was like "wtf, thats rediculous. How about $15/quart". me: SHWING!
#1380355 09/26/05 07:36 PM
F
F
Not sure if anyone addressed this in a post already since I skipped to the end, but Redline MTL should not be used in Contour transaxles for the following reasons:
1.) Both manual & automatic transmission require Mercon ATF
2.) MTL is for standard manual transmissions and is not compatible with or to be used on transmission that require ATF
I have used Redline products for over 10 years and have never had a problem. As a matter of fact, MTL worked wonders in my 89 RX7 Turbo, made shifting smoother, easier and reduced gear noise.
Please note some additional factors about using synthetic oils (including trans fluids), not all products are true synthetics as I recently learned and can lead to serious problems if you try to extend fluid change intervals.
Synthetic products from Mobil (Mobil 1), Castrol (Syntec) and other major oil companies are typically made from Group III base stock (petroleum oil) rather than more expensive Group IV or V base stock (PAO or diesters).
1998 2.0 GL w/auto trans
#1380356 09/26/05 07:46 PM
[sarcasm]No this has never been mentioned. Thanks for helping out though.[/sarcasm]
#1380357 09/26/05 07:50 PM
Y
Y
Funny, this entire thread is turning into a joke too!
Mark
#1380358 09/26/05 07:52 PM
Don't be a tool, he just said he'd skipped to the end.
