Posts: 9,602 |
todras, if you and Terry are right all the time then why hasn't my MTX-75 died since I've NEVER run Ford honey in it??? To boot I've run MTL for almost 2 years previously with out any issues or that "non-MTL caused" build up.
That's what this entire thread is stating like an oversensationalized media blitz. "Run Ford Honey ONLY or your MTX will be destroyed"
Seriously that is what half of the posts are truly saying.
Why is it that the majority of the people with MTX-75's are not running "honey" and are still going strong???
It's funny how real world data, experience, and accomplishments can throw a big monkey wrench in the book theories of others isn't it.
This thread still has not proven that MTL is a bad fluid or has problems. Was that not the entire purpose of this thread???
It certainly wasn't to say the Ford Honey was a good fluid option. That was already a given long before this thread started.
When is the PROOF coming that MTL is without question a "BAD" fluid??? I bet it never does. To be honest it would be hard to prove considering the POS choice to use ATF in the first place. You can't argue MTL, MT-90, or SyncroMesh is not better then any ATF. We won't even get into ATF with added LSD FM because that's been proven to be a horrible choice for longevity.
Also did you notice how those "European experts" stated that zinc/sulfur packages were used to safely improve gear oil's anti wear properties without hurting the MTX. Then they also agreed with our post from nearly 3 years ago that GL-5 is never an option. They are not helping your case to prove MTL or our (this site's nobody CEGer's as you put it  ) original thinking is bad.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 2,033 |
holy [censored] has this thread grown!!  all i wanna know is what to run...
Posts: 21,197 |
Originally posted by DemonSVT: todras, if you and Terry are right all the time then why hasn't my MTX-75 died since I've NEVER run Ford honey in it??? To boot I've run MTL for almost 2 years previously with out any issues or that "non-MTL caused" build up.
Luck. I never said anyone was right all the time. You have an LSD. You don't have planet gears with oil galleys that can get clogged. Did it have a black residue when you opened it up after running MTL? Have you actually seen the inside of it?
No one has ever said that! Where are you getting this from. Terry suggested RP S.M. as well as Mobil 1!
Because they are running ATF which terry said would be fine. Ford Honey is the best as stated a million times. THe MTX-75 will be fine with ATF which was the previous spec. Has since been changed to Honey as stated over and over.
Funny isn't it. What are you bringing to the table?
Oh really? It's been proven all along and also backed up with facts. Now if you fail to read everything I can't help that. I'm not cutting and pasting any more. It's all been laid out.
I thought that's what we were talking about in this thread.
And how has that been proven. Missed where ATF is leaving a black residue and sludge on the inside of MTX-75's.
I missed where it said that. Could you point that out?
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,322 |
Originally posted by morbid: Ok... I would guess that the darkness and smell of the MTL is ONLY from failing/failed tranny and/or differential. I've changed my MTL 2 times (about 10,000-12,000 miles apart) and each time it looked almost like new -- no smell, cherry red, and no metal flakes. I just changed out the MTL for a 3rd time about 2 weeks ago. My diff began failing yesterday and I drained it when I got home. It stank like hypoid, was dark brown/red... and was filled with metal flakes (looked like a ricer paint job). The drain plug was even gouged and scraped
I am definetly NOT blaming the MTL -- I do abuse my car. I AM saying that the nastyness that Terry has found in the trannys are most likely ONLY a result of a failed tranny/diff (probably due to extensive heat generated by the failing components -- my tranny. Why else would he be working on a tranny if it hadn't already failed?
MTL is not cherry red, are you sure? Have you been using ATF?
We just did a fluid change on an SVT this weekend, no red color at all in the MTL we drained, and definately no red color in the fresh MTL we filled it with. No red color in the MTL I filled my SVT with in May.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 21,197 |
Originally posted by G�¨t�£uck�¥151: all i wanna know is what to run...
If you're leaning toward MTL this might even be better if you're stuck on running a Redline product.
15W40 diesel.
-'96 SE MTX 3L
Posts: 21,197 |
Let's make something clear to you and the rest. Terry has no axe to grind against MTL. Having seen the effects he started digging. This could have been Royal Purple, Amsoil etc. That is not his issue, the issue is what he's seen. Why do you guys keep thinking this is a specific dig at redline? So stupid and closed minded!
-'96 SE MTX 3L
Posts: 21,197 |
FYI MTL has a pinkish redish hue to it when new. When slightly used it turns into a brownish/black red.
-'96 SE MTX 3L
Posts: 2,033 |
Originally posted by todras: Originally posted by G�¨t�£uck�¥151: all i wanna know is what to run...
15W40 diesel.
well all i wanna run is the stuff thats better from all the tests and whatnot that have been discussed...whether it be the Ford stuff, or whatever.
Posts: 2,483 |
Originally posted by G�¨t�£uck�¥151: well all i wanna run is the stuff thats better from all the tests and whatnot that have been discussed...whether it be the Ford stuff, or whatever.
Ford "Honey" is the best choice.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 2,353 |
I've never experienced that. The fluid that Marky and I changed last weekend came out a medium amber color, just a smidge darker than the new MTL we put back in.
Funny how Terry comments that a heavier fluid should be used ala Ford Honey, but you still recommend ATF which is the lightest fluid mentioned.
I'll stick with what I've seen and experienced in my own car. 60,000 mi of perfect use over 2.5 years with a stock diff using MTL compared to obvious wear and notchy shifting using Mobil 1 for a mere 5,000 mi.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
