Posts: 710 |
you can just hit amsoil and click the usage/application button. It said our mtx uses 5w40 synthetic motor oil + additive
morbid
2000 Contour SVT (black)
Posts: 4,693 |
I found the Amsoil listing. It still isn't very clear. Besides recommending 5W40 synthetic engine oil, there are footnotes. One says SLF is MT fluid meeting spec WSD-M2C200-C and the other says additive needed (could that be friction modifier?).
The same manual trans fluid showed up when I plugged in a 2002 Mercury Cougar.
1998 FORD CONTOUR 2.5L 6-cyl VIN Code G HO
BOSCH SPARK PLUGS SVT Wire......B09402 Plug......B4458
BOSCH WIPER BLADES Driver side......B40922 Passenger side......B40920
FILTERS Oil Filter......SDF11 Oil Filter Qualifier......HO Oil Vapor Filter......N/R Oil Vapor Filter Qualifier......HO Air Filter......AF307 Air Filter Qualifier......HO Fuel Filter......GF115 Fuel Filter Qualifier......HO Fuel Vapor Filter......N/R Fuel Vapor Filter Qualifier......HO PCV Valve......HV193 PCV Valve Qualifier......HO Cabin Filter......AF1002 Cabin Filter Qualifier......HO
LUBRICANTS & FLUIDS Engine Oil Grade 1......API* Series 2000 Synthetic 0W-30 Motor Oil SAE 5W-30 Synthetic Motor Oil SAE 5W-30 XL-7500 Synthetic Motor Oil Manual Transmission,.....SLF[1][2] Synthetic 5W-40 European Engine Oil Automatic Transmission.....MA Synthetic Automatic Transmission Fluid Fluids Power Steering Fluid.....MA Synthetic Automatic Transmission Fluid Brake Fluid.....HBH
1. SLF is MT fluid meeting spec. WSD-M2C200-C 2. When replacing fluid, add 1.8 oz. (52 ml) of additive . specification No. EZL-401.
CHASSIS LUBRICATION 0 Fittings, 0 Plugs
CAPACITIES Engine, with filter..........5.8 quarts[1] Cooling System, Initial Fill..........9.0 quarts Automatic Transmission, Initial Fill..........3.9 quarts[2] Automatic Transmission, Total Fill..........10.0 quarts Manual Transmission, ..........5.5 pints
1. After refill check oil level 2. With ENG automatic transmission operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
TORQUES Oil Drain Plug.....16-22 ft-lbs Manual Transmission Fill Plug.....29-43 ft-lbs Drain Plug.....29-43 ft-lbs
CAUTIONS ENGINE Remove the engine oil dipstick when refilling in order to avoid contamination of the PCV system.
SERVICE INTERVAL AMSOIL Product Change Interval Guide (g1490)
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,570 |
Originally posted by Swazo: So according to this chart...Originally posted by rkneeshaw3.0: lube chart
..... Synchromax is recommended from RP.
Looks like you're right!
Specific reference page here:
http://www.royalpurple.com/techa/tranxref.html
So far, looks like approved fluid list is:
Ford Honey (no additive required)
RP Synchromax (meets ford honey specs, no additive required)
Amsoil 5w40 (need clarification yet on additive?)
Posts: 4,693 |
This also goes with the Royal Purple listing. It actually gives the Ford Part number and spec with it's reference to Synchromax. http://search.freefind.com/find.html?id=35546555&pageid=r&mode=ALL&n=0&query=M2C200-CTo make sure that the above link does't disappear, here is a cut and paste. Site Search Results Search Results From The Royal Purple Website Found 1 items, now showing 1 - 1 search tips Home Page << Prev | Next >> NewRefine 1. Royal Purple Synthetic Oil Transmission Cross Reference Chart 04874464 Synchromax Ford Manual Transmissions XT-M5-QS spec WSD-M2C200-C Synchromax Transaxles F32Z 19C547-MA Max-Gear 75W90 All Models XT-2-QSM Synchromax All Models XT-5-QM What doesn't transfer is the window where I plugged in M2C200-C
Jim Johnson
98 SVT
03 Escape Limited
Posts: 128 |
I was talking to the tranny guy at the local ford stealership today and he said that you should use straight ATF, no FM at all in the tranny. and i also put in redline mtl in my new tranny today, i want to reduce the noise from my torsen, and cause i ain't scared.
2003 Dodge SRT-4
Mods: more than 250 characters worth!
Posts: 4,970 |
I'm going to break in my 'new' HMS trans with ATF+3 for 500 miles, and then switch to RP Synchromax.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 5,810 |
See My Mods
Posts: 4,693 |
That is extremely interesting. It is the 2002 version of the chart that was posted earlier today. The chart on the bottom of the page is for manual transmissions. One of the footnotes says: "XT-M5-QS" (what we know as Ford Honey) "Replaced SAE 80W manual trans fluid F2ZZ-19C547-A."
I think that F2ZZ-19C547-A is a multi viscosity GL-4 gear oil. I'll try to see if I can find anything about it.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,693 |
I didn't find what I was after, but I did find something better. I found a Ford site with a full descrption of XT-M5-QS. Follow this link and then go to page 15. http://www.fcsdchemicalsandlubricants.com/fad/pdf/catalog.pdf Ford says that "Ford Honey" is GL4, 75W90, just like I posted two years ago.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 123 |
Just to muddy the waters a bit more  , my hardcopy '1996 Contour/Mystique' Service Manual (copyright 1995) shows the following fluid specifications: My glovebox manual states to run 'Mercon ATF' (no mention of any Friction Modifier). I just got my 96SE running again after installing Clutch/Forks/Torsen. The Torsen sure 'rattles,' but will hopefully quiet down when it has more than 2 miles on it! For the break-in, I'm running straight ATF. After that, I'm leaning towards using RP-Syncromax, as RP's specs reference Ford's Honey (even though I have 3 bottles of RedLine MTL sitting in my garage).  I ran the Mobil/FM Cocktail for 70K+ miles -- never had a shifting problem and the transmission was shiney/spotless when I opened it up last weekend. I'm of the opinion that the greatest factor in the protective abilities of an MTX fluid is the regularity of drains/fills and user driving habits. I feel comfortable with the 20K mile MTX fluid changes.
1996 Ford Contour SE (Mine): V-6 MTX/DMD/MSDS/K&N3530/Torsen/Spec-1/Split-Exhaust/Walbro/Syncromax..119K
2003 GMC Yukon XL SLT (Hers): 285HP/Stock..93K
