NO, the input shaft is 18 mm too short ... this is why you can't use the Quaife gearset in the V6 MTX-75 ... it's made for the Focus I4 MTX-75 which is different for a reason.
BTW, 18 millimeter = 0.708661417322835 inch ... that's nearly 3/4 of a inch ... imagine the clutch problems! The only way around this is to create a .70866" solid billet "shim" to place between the crank & flywheel ... NO THANKS!
I should have figured it wouldn't be that easy; I have a new take-out MTX-75 out of a Focus and can't use it. Oh well, thanks to all for the information...
per TH "....does not have the same stud spacing on the trans case mounting as the Contour/Cougar*The Focus 'speedo' is a side mount sensor with a trigger wheel Vs the top mount Contour/Cougar type*Bellhousing and input shafts also will not match a V6...."
