Originally posted by SVT:
I went to my local body shop and they mixed the red using a paint scanning device. The color code should be in the driver side door jam.
I went to a local car parts store and bought high temp engine clear coat.
Hope this helps.
From my understanding of High temp paint, it allows the heat to pass through it therefore staying cooler and not allowing the paint to be affected by the heat. If you put regular paint on there with hi temp clear on top that wouldn't really do any good because the base coat is still taking all the heat. This may lead to cracking or even flaking.
