I have a 2000 Contour Sport with a temp. disabled blower motor. Worked fine yesterday and nada today. Is this the resistor pack that everyone talks about? I did check all 3 fuses/relays, working. I did check to see if 12 volts was going to blower motor, it is. Didn't know about the resistor pack...will check. Also, if the blower motor is bad, how do you get it out? And another thing, upon checking for new blower motors...seems most don't come with the wheel? Any and all help will be appreciated in this Texas heat without AC!
