#1377393 09/03/05 11:30 PM
mcfast Offline OP
How to remove the bolt that holds the front LH lower control arm, it buts up on the transaxle, and the bolts that hold the subframe spin freely.
SVT 99 #526 of 2760
#1377394 09/04/05 01:38 AM
I hate to tell people this but use the search tool. You will find lots of info searching LCA. You will also find info on where to find the access holes to grab the nuts that spin freely.
#1377395 09/06/05 05:09 PM
Undo the nut, then lift it up and stick a sawzall under the head and cut the head off. Then when you reinstall the bolt stick it in from the bottom - I've done this and NEVER had an issue.
Just make sure you use a Grade 8.8 or better bolt of the same diameter and a locking nut, or use two nuts so you can jam them together so they don't come loose.
#1377396 09/06/05 05:14 PM
Yep. Just as Stazi said. Ace/True value usually carry 8.8 or higher bolts.
#1377397 09/07/05 01:24 AM
mcfast Offline OP
That is what I was thinking, of doing. Thanks
SVT 99 #526 of 2760
