Page 2 of 2 1 2
Originally posted by SVT PETE:
Sorry, not into the rubber band look.
dont i have your old 19z?
19's all the way. the car still rides great and never had a issue. i for one cant stand pizza cutter 's ( small rims and tires) lol
autox fil... you have to consider tire weight not just rim weight and mass.
The mass of the tires in some cases is MORE than the wheels themselves.
I noticed this when switching from 16" Rota Grids (14.5 lb wheels) to Centerline RPM 19" (15.5 lb wheel)
the Centerlines dispite being a lb heavier in the rim are actually Signifcantly lighter than the 16" Rotas.
The Sidewall difference between the 16" and 19" wheel is HUGE! and that sidewall difference ADDS alot of weight in the Outermass of the wheel/tire assembly. The rim itself is significally lighter overall than the tire.
Additionally I tested my observations on the 1/4. Gained and avg of 2mph and .2 seconds running on the 19" wheels vs the 16" wheels. Dispite similar 60ft. These where taken using an average of about 10-15 runs with each setup.
Cougar V6 MTX: GMK Carbon Fiber Cold Air Intake : SVT UIM : SVT LIM : SVT TB : MSDS Headers & Ypipe : TruBendz 2.5" Borla Single Exhaust : Soild Front Motor Mount : & more
BFG KDW2:
225/45 YR17 - 24 lbs 25.1" OD
225/40 YR18 - 28 lbs 25.1" OD
225/35 YR19 - 24 lbs 25.2" OD
Fuzion ZRi:
225/50 WR16 - 24 lbs 24.9" OD
225/45 WR17 - 25 lbs 25.0" OD
225/40 WR18 - 24 lbs 25.1" OD
225/35 WR19 - 24 lbs 25.2" OD
Goodyear GS-D3
225/45 WR17 - 23 lbs 25.0" OD
Where's your magic weight loss? The data don't lie. It seems that the loss of sidewall would lose some weight for you, but it just doesn't work, mostly because the steel bead gets longer as the sidewall gets shorter. You happen to be gaining a tiny bit of overall diameter with these sizes, but it's pretty negligible: 0.4% per step.
Also, you obviously got different tires with your wheels. One lb on your overall setup isn't going to make as big a difference as new or different rubber, a wider or flatter contact patch (did rim width change?), or your better driving with more experience.
So, you definetly save weight by going with a smaller rim. This will make you faster, all other factors being equal. How serious you are about your drag times vs. street pimp factor is probably the deciding factor. For road race, you will get better response with a thinner sidewall, which can make you faster. GRM had an article about this topic, where they compared different size tires on a Honda. The problem I see with the article is that they added tire and rim width as they increased the rim diameter. It shows a speedup with low-profile tires, but they only went to 17", IIRC - and there was a bigger increase between 15-16 than 16-17, indicating diminishing returns, which are to be expected. I'd wager that a test between sizes on a Contour would show that the fastest setup is a 17", but it could very well be a 16 or 18, and vary significantly depending on the car setup, and the tire chosen for the test.
But most of our cars are on the street exclusively, and the few that see the drag strip, autocross, or road course don't spend a large percentage of their lives there. So for the use of the car most of see, the difference is slim to nill. I run 16s because - a) they are at least as fast as any other size within my abilities to wring the last bit out of them b) I got them for cheap c) tires in 16" are cheap. I also prefer smaller wheels look-wise: 225/45R17 on a BBS-style wheel is what I'd roll if money was no object, but the way I go through tires the savings are big. If you have the money for large wheels (maybe because you manage to make summer tires last more than 5k), and you like the look, then that's great for you. But a smaller wheel will result in a lighter total combo, and the tiny sidewall on huge setups is not a real advantage.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
I think this is more of west coast thing. folks in the mid and east states are more conservatice. here in the west coast, cars are more aggressive etc.
TGO Offline
Originally posted by 98Ford2L:
Originally posted by KingpinSVT:
19's are defintely too large.
I agree, even 18's are larger than I'd want.
-Peter
i tihnk 18's are the perfect size for the contour, atleast the SVT. 17's look too small unless your car is seriously dropped, or you have pretty low profile tires.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
You do. Thought I'd give them a shot due to how light they are. The ride was just too rough and the rubebr band look wasn't for me. Currently have 18" Superleggeras and loving it.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
what size tire are you running on the Ozs?
Ive been considering the 18" superlegras, Love how they look!
Tho i always told myself i wouldnt go above a 17" wheel
Page 2 of 2 1 2
Moderated by  1314_dup1
