Posts: 2,116 |
95 SE MTX
svt exhaust
intake
deer killer
Posts: 425 |
that is some nice information, nice find
1998 Ford Contour Se 2.5 litre Silver frost
Posts: 1,303 |
wow a good read. i did not know the v8 yamaha sho engine was based off the 2.5 (with 2 cylanders added). good find.
Goonz12: <---tries on mommy's cloths
Posts: 301 |
Originally posted by DopePope: wow a good read. i did not know the v8 yamaha sho engine was based off the 2.5 (with 2 cylanders added). good find.
I didn't know that either, and I'm not sure if it's accurate. I was under the impression that it's a 100% Yamaha design. Furthermore, those engines had MAJOR problems because the pressed-on cam sprockets come loose and eventually freewheel, which causes the pistons to smash the valves. I've never heard of that issue with any Duratec.
In fact, it's probably closer to the other way around--I've heard that Ford learned quite a bit from the original Yamaha V6, and it influenced the modular V8 and Duratec engines. That's just hearsay, but I believe it considering the design similarities (DOHC, 2-stage intake, similar hp/liter, etc).
'99 Contour Sport V6 MTX
Posts: 1,303 |
Originally posted by rearden: In fact, it's probably closer to the other way around--I've heard that Ford learned quite a bit from the original Yamaha V6, and it influenced the modular V8 and Duratec engines. That's just hearsay, but I believe it considering the design similarities (DOHC, 2-stage intake, similar hp/liter, etc).
wouldn't that slightly go against the fact that the 2.5 is a porsche design?
Posts: 301 |
Originally posted by DopePope: wouldn't that slightly go against the fact that the 2.5 is a porsche design?
Ahh yes, I forgot about that! Pretty much invalidates that rumor, at least for the Duratec.
Another Duratec-related tidbit: A few years ago I read a book called "Car". It was a great read that discussed what happened behind the scenes at Ford when they were designing the '96 (oval) Taurus. Evidently when the Ford execs heard that Cadillac had named their engine the Northstar, they loved the name and wished they had thought of it. One of them lamented that "Duratec", by comparison, sounds like the name of a pair of pliers.
Posts: 1,786 |
The entry also states "both Aston Martin and Cosworth are owned by Ford" which isn't true. Why would Cosworth produce engines for Chevrolet Indy cars?
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 1,194 |
Originally posted by rearden: Originally posted by DopePope: wow a good read. i did not know the v8 yamaha sho engine was based off the 2.5 (with 2 cylanders added). good find.
It's accurate. On the 3.4L SHO V8 only the cylinder heads were of Yamaha design. Everything thing else was Ford.
Posts: 21,197 |
Originally posted by �¡ Se�±iorSiesta !: The entry also states "both Aston Martin and Cosworth are owned by Ford" which isn't true. Why would Cosworth produce engines for Chevrolet Indy cars?
Because at the time when the V12 was being built Cosworth was partnered with Ford. They have since split off.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
