Page 4 of 4 1 2 3 4
What happened to sending back that license plate frame?? j/k... laugh
-Louis
1998 Black E0 #3826, lightly modded
so how did you exactly prep the grill. u mentioned that you preped the svt emblem, but not the grill along with the mesh. i know that the mesh is grey made with plastic the the border is chrome. how did make it look so good? also did you use clear coat and how many layers of paint? thx.
Spec 23
99 SVT
No Mods (can't afford to void the extended warranty)
1
1
Same as the emblem. Sanded it down enough to rough it up. Sprayed it with epoxy primer and sprayed it with single stage. Didn't see a reason to use base coat clear coat. Still matches perfectly. The mesh is still like it was from the factory. I just cleaned it good.
really? my mesh is a grey color. huh... well thx for the help. did you use ford factory paint?
Spec 23
99 SVT
1
1
So is mine, Yes and no, Almost all black paint is black paint
Page 4 of 4 1 2 3 4
