Posts: 9,872 |
the pro's at a P1131 is that a bad O2? would that explain why my cat/exhaust STINK thanks
Posts: 5,345 |
Originally posted by Goonz SVT: the pro's at a P1131
is that a bad O2?
From TSB, it could be any of this.
HO2S-11 (Bank 1 Upper)- Lack of HO2S-11 Switch, Indicates Lean When an HO2S sensor indicates lean at the end of a test, the system is trying to correct for an over-lean condition. The code is set when the fuel control system no longer detects switching for a calibrated amount of time.
Electrical:
�· Short to VPWR or VREF in harness or HO2S
�· HO2S circuit shorted to Ground
�· Water in harness connector
�· Open circuit
�· Corrosion or poor mating terminals and wiring
�· Damaged HO2S
�· Damaged PCM (other DTCs should be present)
Fuel System:
�· Excessive fuel pressure (stuck fuel pressure regulator, restricted fuel return lines, etc.)
�· Leaking/contaminated fuel injectors or fuel pressure regulator
�· Low fuel pressure or running out of fuel (fuel pump concern, fuel supply line restrictions, low fuel level, etc.)
�· Vapor recovery system (stuck VMV, etc.)
Induction System:
�· MAF contamination
�· Air leaks between MAF and throttle plate
�· PCV system / Other vacuum leaks
�· Improperly seated engine oil dipstick
EGR System:
�· Leaking gasket
�· Stuck EGR valve / Leaking diaphragm or EVR
Base Engine:
�· Oil overfill
�· Incorrect cylinder compression
�· Exhaust leaks before or near the HO2S
�· Secondary air stuck on
1996 V6 ATX 96K miles
Posts: 9,872 |
omg! wtf! where do I start?!?
Posts: 5,345 |
Fuel System:
Induction System:
EGR System:
�· Leaking gasket
Base Engine:
�· Oil overfill
