Page 6 of 7 1 2 3 4 5 6 7
I just checked this morning, seems an extra full quart is needed. So I'll be doing oil changes with 7qts of oil now. I can't comment on the benefits of a larger filter, but I can say that oil changes will be MUCH less messy and easier with the filter over there.
I did the kit for two reasons really:
1. Easy hookup of my oil pressure and temp gauges in an ideal location
2. Easy, clean oil changes
3. It's badass
Ok 3 reasons I guess.
I'd think you would need to run more oil with the relocation kit and a stock size filter right?
ya, probably only need .5 qt more oil with a stock filter. The FL-1A is like twice as big as a stock filter. I'm not sure if this adapter will let you use a stock filter though. The instructions with it say to use the FL-1A. The threads may be different.
Cannot use a stock filter! I will be ordering this kit, but I wanna mount mine in the engine bay under where my battery used to be!
Cool Toe Chris
Cool Toe Chris
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢:
(snip)...but I wanna mount mine in the engine bay under where my battery used to be!
That's where mine is installed. Makes for a simple and clean oil change.
Chris NJ 98.5 SVT Silver Frost
Pics?
Yea mine looks like your Ryan. I think I posted that I had to switch sides because my temp probe wouldn't reach. Good job! Looking good!
So guys, how much extra oil have you end up running with this relocation?
My buddy already makes fun of me because i need 1.5 quarts more than his SUV :P
Okay...many european cars use 7-9 quarts.
Order soon, it takes about 6 weeks to get it. It can be purchased through summit racing but its special order. I couldn't find anyplace that had it in stock.
I'd like to see pics of it mounted under the battery tray too. I couldn't see how to get it isntalled in there without the A/C component preventing the hoses from making a 5" radius bend. The isntructions say the hoses should not be bent anymore than a 5" radius to prevent blockage.....
