Page 1 of 7 1 2 3 4 5 6 7
I was trying to figure out the best place to plumb my mechanical oil temp probe so I sent an email to Terry Haines about the best way of doing this. I read some posts about ppl plumbing into the oil pan and wasn't sure this was the best way. This is bad for a couple reasons.
1.) The oil pan is very thin and leaks could occur. Brad Noon messed around with the oil feed for his S/C many times. I think the leak was so slow he gave up.
2.) You will receive a "cold" reading of your oil temp in the pan.
The way to get the most accurate reading is to plumb it into a flow area. This is where Mr. FRP relocation kit for Ford mudular motors comes into play.
This is a pic of the kit I installed.
This kit has two extra ports for pluming oil pressure, temp or another filter if you so desire.
On with the install.
I took the portion you thead onto the stock oil filter head and threaded in the nipples. Better to do it off the car for obvious clearance reasons. Don't forget to wrap the threads with teflon tape kids. We don't want any leaks. After tightening them down I threaded it onto onto the block.
Then I figured out the best place would be underneath the bumper area. This is the same way Buckshot did his I believe. The pic I had is at work. So obviously you're going to have to remove the bumper cover so you can get a drill and wrenches in this area. Sorry bumper was already off car. You'll have to get a manual from me if you can't figure it out.
After measuring 20 times and drilling once I bolted the filter housing to the chassis and routed the hoses through the fender area, over the subframe. The hoses are then secured to the front portion of the subframe. Then plumbed into the block mount. Don't mix up the out and in! The block mount has out and in labeled. The filter housing has arrows designating flow in and out as well.
When all said and done this is how mine looks. I bent the horn bracket down a little bit for clearance. I will now be running a Motorcraft Fl-1A filter which can be found almost anywhere and will filter a lot better than stock. Of course I couldn't find anyone in the area close to my home that stocks Motorcraft so I threw on a Purolator PureOne since it's guts are the same as an FL-1A but a little pricier. Walmart stocks them but of course they were out since the filter is used on so many Ford applications.
do you think it would fit under the battery so you wouldn't need to pull the bumper when you wanted to change the oil? how about fitting the sender for an electric oil pressure, you think that would fit also?
you can get to it without taking the bumper off, just lie on you back and look up between the bumper and the wheel, it's a open spot.
i've seen cars with battery relocation done there. with time and parts it's possible.
1998 Ford Contour Se 2.5 litre Silver frost
If you did all this to hook up an oil temp probe, how accurate would it be behind the bumper while the cars in motion?
www.ChicagoCEG.com 2006 White Grand Prix
Yes the filter is fairly easy to change. Still have access with removing anything. And Bk I have no idea WTH you are asking.
Would you get an accurate reading behind the bumper with the air circulation that occurs there?
I have a cheapo ricer temp gauge in my car and have no idea where to hook it up. I was actually just searching for options the other day...And this does seem like a godsend...But during the winter months your reading will probably be a bit different due to outside conditions and being farther away from the motor don't you think?
Steve air flow is not going to effect oil temp. readings! By cold I mean it's oil that is not being circulated. It will be a lower reading than oil that is flowing through the engine.
OH!!! Thanks Todd. I wanna hook up the temp gauge I have in my pillar, but Hector sold the Wein_Seans old Duratec before we had a chance tolook at it.
Kevin also has a remp gauge to hook up so we're trying our damndest to find out wheres a good place for the sensors...
I'm putting mine in the head.
CSVT Feels Like Heaven Goes Like Hell Profile
Hey Todd, is it possable to run a oil cooler after the output of the filter ? Wouldn't be a bad idea of cooling the engine oil ?
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
