#137144 10/04/01 12:50 AM
Just read on the DRL relay check. Turns out i do have the "slot" open for the relay. 3 Questions: where can i get the relay? is there any other equipment i need? and if it works, are the low beams on or the high beams at lower wattage?
Thanks
#137145 10/04/01 12:54 AM
I would try a Ford dealership. I think that it runs the low beams. I don't know for sure though.
-Colter
My Car
#137146 10/04/01 01:21 AM
Lee Offline
They run off of the low beams and are reduced brightness...The Canadain Cars have them so you might want to see if one of our Northern Brothers can get it for us.
Lee Cox
In life begins responsability...
Project Car
#137147 10/04/01 02:03 AM
Master P
Master P
Part number F5RZ-14N089-E, list price should be around $26, you can get it from Bill Jenkins.
And it's the high beams at lower brightness. Reference for that fact.
#137148 10/04/01 02:53 AM
E
E
I'll second that Perry.
Hence the inside bulbs will be lit on 98+ cars.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#137149 10/04/01 03:01 AM
They actually run off of the high beams. It is also true that they run at a lower wattage. But at least on my car they do use the high beam. Hope this helps
wink
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
#137150 10/06/01 05:34 PM
Y
Y
The DRL's run lower wattage off the HIGH beam bulbs (inside lights) on both PRE and POST '98 cars . I know this for a fact as I've owned both styles as well as my bro having a '95 and my mom with a '98 Mystique with DRL's . I got all of the relays for the cars at the dealer for about 25 bucks (USD) . Remove the "buss bar" in there & plug in the relay & bingo ... DRL ! laugh
Good luck !
~~~~~~~~~~~~~~~Allen
********** Love Those REDWINGS !!! **********
2000 Contour SVT Black w/ Tan #2137 of 2150 / built 2-4-00
Mods : ~ Factory DRL mod ~ "Powered by Ford" seatbelt covers
~ OF's TH fix ~ Audi A-6 Side Repeaters ~ Highs in Lows Mod
~ #885 foggies ~ KKM filter ~ Mondeo ST200 Badging & Shiftknob
~ Pre-98 Sails ~ Nose Bra ~ Trunk cargo net ~ '98 Clock
~ "Glasspacked" Resonator ~ Painted Rear Reflector
~ Räzo Pedals ~ Custom "Mondeo" Windscreen Banner ~ Ventvisors
~ Lighted Moonroof Switch ~ Mystique Rear Seat Light
~ Painted Grille Ring ~ H&R Springs & Mondeo ST200 Struts
~ Mille Miglia "Cello" Wheels
My old 95 \'Tour SE ~ New SVT pics here
#137151 10/07/01 03:03 AM
Buss bar? confused Mine is just an empty slot.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#137152 10/08/01 01:01 AM
Y
Y
Is yours an empty HOLE ?? If it's an empty HOLE , then the relay is a no-go frown . There's some fancy wiring needed if that's the case . If it's an empty white plug , it should have a gold "jumper" bar across 2 of the slots in the plug . Just undo the "jumper" & plug in the relay .
Your car is a '95 SE , so it should have the plug ...
~~~~~~~~~~~~~~~~Allen
#137153 10/08/01 03:41 PM
Wasn't it that if your Contour was built in Mexico, most likely it DOESN'T have the relay plug/buss bar while the ones built in Kansas City DID have the relay plug?
P. Valdez
1998 VW Jetta TDI
1.9L I4 direct injection turbo diesel
5 speed manual
no mods, no money
AIM:PackRatTDI
My exhaust smells better than yours.
