Posts: 5,345 |
Originally posted by ValCor: ... P1131. Gonna try cleaning my MAF sensor to see if that works. ..
And you also found this post, I hope.
Originally posted by Tony2005: Originally posted by Goonz SVT: the pro's at a P1131
is that a bad O2?
From TSB, it could be any of this.
HO2S-11 (Bank 1 Upper)- Lack of HO2S-11 Switch, Indicates Lean When an HO2S sensor indicates lean at the end of a test, the system is trying to correct for an over-lean condition. The code is set when the fuel control system no longer detects switching for a calibrated amount of time.
Electrical: �· Short to VPWR or VREF in harness or HO2S �· HO2S circuit shorted to Ground �· Water in harness connector �· Open circuit �· Corrosion or poor mating terminals and wiring �· Damaged HO2S �· Damaged PCM (other DTCs should be present) Fuel System: �· Excessive fuel pressure (stuck fuel pressure regulator, restricted fuel return lines, etc.) �· Leaking/contaminated fuel injectors or fuel pressure regulator �· Low fuel pressure or running out of fuel (fuel pump concern, fuel supply line restrictions, low fuel level, etc.) �· Vapor recovery system (stuck VMV, etc.) Induction System: �· MAF contamination �· Air leaks between MAF and throttle plate �· PCV system / Other vacuum leaks �· Improperly seated engine oil dipstick EGR System: �· Leaking gasket �· Stuck EGR valve / Leaking diaphragm or EVR Base Engine: �· Oil overfill �· Incorrect cylinder compression �· Exhaust leaks before or near the HO2S �· Secondary air stuck on
1996 V6 ATX 96K miles
