F
F
wel, went last Sat. to have the inspection/emissions test done before taking the CSVT back to St. Louis. I dont know which code #'s were tripped,just the Diag. read out.. says bank 1 & Bank 2 cam sensor failure codes & bank1 top o2 sensor.
I had a bout of bad gas causing lots of mid-range light detonation about 2 weeks prior to the inspection & the CEL came on & then went off so "no worries" I figured I knew of the bad gas... well the night before the inspection I cleader the codes (so I thought)& took her in.. they did their little test & the CEL came back on with hard codes only...
Do I really have 2 bad Cam Position sensors? im not worried about replacing them, but won't if I should be chasing something else. the 02's are a no brainer.. I'll do all of them at once..
thanks
ROb W
F
F
sorry didnt realize the troubleshooting section existed....
Rob W
Did you get this code ?
Click here
98 Contour GL/03 ZX3 Focus/05 ZX3 SES Focus
Originally posted by futureownerSVT:
welsays bank 1 & Bank 2 cam sensor failure codes & bank1 top o2 sensor.
.....thanks
ROb W
For Camshaft sensor. Code P0340, the one in yellow.
Originally posted by chongo:
It will take you 5 minutes.
Unscrew one bolt, pull out sensor, screw in bolt!
For Bank 1 Upper O2 sensor a little harder. Don't change all the O2 sensors if you don't need to.
Edit. Bank 1 Upper O2 sensor
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=1023912&Forum=All_Forums&Words=19843&Match=Username&Searchpage=0&Limit=25&Old=allposts&Main=1023736&Search=true#Post1023912
